I'm curious about the necessity of the intake port adapter. I've not done the valve cleaning yet. I did just do a PCV valve replacement at 76,000 miles and the intake valves, surprisingly, had very little build-up. And, I'm stage 2 dual pulley and have been at stage 1 or higher for over 50,000 miles.
Two questions:
1. Why not just cut out a cardboard template to cover the ports on each manifold and make a small hole over each port to insert the blaster wand/tip? We've done that for years on other direct injection four valve (twin intake valves per port) platforms. Costs zero and works fine.
2. Why are many intakes very carbon and "gunk" crusted, while others are not? I'm just running 93 octane pump gas. No meth injection or anything else.
At 76,000 miles my intake valves only looked like this, so I left them alone:
This is typical of all cylinders.
