    Veteran Member Four Rings Quattro 4 Life's Avatar
    Feb 05 2008
    '64 Pontiac Catalina
    Kenmore
    S6 - P0706 - Range Sensor (F125): Implausible Signal
    My project S I picked up a couple months back has a big drivability issue with this TCU code. Car slams into reverse violently which puts the trans in limp mode. Quickly reset by turning the car off and on again but having to do this each time I pull out of the garage is troublesome.
    Anyway, I’ve picked up a new transmission range sensor and finally had a look underneath the car to see where it’s at.
    I didn’t grab any pictures but it’s nestled very close to the driver side mounting bracket and downpipe.
    For those that have replaced this sensor, what all did you have to remove?
    I’m thinking the driver side trans mount and bracket; hoping to work around the downpipe if at all possible.
    I’ll get some pictures added when I can.
    2007 Ibis White B7 A4 Avant 3.2QM Titanium - 1 of 2 | 2013 Glacier White Metallic 4L Q7 3.0 TDI
    Past: 2013 Phantom Black C7 S6 Stage 3 | 2003 Brilliant Black C5 S6 Avant | 2011 Quartz Grey C6.5 A6 3.0T Prestige | 2000 Silver C5 A6 2.7TQM | 1999 Laser Red B5 A4 1.8TQM PC-16
    Established Member Two Rings rovert6's Avatar
    Jan 13 2016
    2003 A4 B6 2.7t Quattro swap
    Raleigh, NC
    It’s a pain in the ass. I had to change mine out on my 03 allroad recently. I had to take off the drivers side downpipe heat shield, drop the front subframe a bit, and remove the transmission mount and mount bracket bolted to the side of the trans. There is very little space to work, and any thin ratchets or short Allen keys you have to squeeze in there will help tremendously. I think I had to go from the top to get the very top Allen bolt for the trans bracket iirc. It took me a solid 3-4 hours working on the ground to replace it. Tore my arm up to pieces from the tight space. If you have smaller arms/hands, it can be a little easier
    K04 / CUSTOM TUNE / 3" MAF / 386CC INJECTORS / FMIC / RA4 STAGE 2 CLUTCH AND LW FLYWHEEL / CUSTOM EXHAUST, AND MORE TO COME
    Apr 27 2015
    Spokane WA
    I had to do this on my S6 a few months ago. Dropping the drivers side down pipe and trans mount makes it doable but I will agree it is a pain and a solid 3-4 hours if done on your back in the drive way. Dropping the Dow pipe wasn’t to difficult as we have a larger trans tunnel than the Allroad’s. Good luck.
    Feb 05 2008
    Kenmore
    Appreciate the replies. I was back under the car this weekend and can see why the downpipe has to come out. This isn’t my daily so I will be slowly pecking away at it.
    Might tackle a bad outer CV joint and drop the driver axle while I’m right there.
    Feb 05 2008
    Kenmore
    Closing the loop for anyone who stumbles upon this thread in the future.
    I chipped away at this and a number of other issues with the car over the last few months and did indeed pull the driver side downpipe and the driver side trans bracket. I also had the front driver side axle out for a CV repair which really opened things up.
    One issue I ran into was the wire harness on the sensor I bought was shorter than the original one. Had to reroute part of the harness to make it work. I bought a $40 replacement off eBay, YMMV.
    Part numbers for reference:
    Trans range sensor: 01V919821A
    Exhaust coupling: 191253141G
    Exhaust manifold nuts: N91130801
