P0240 Turbocharger/Supercharger Boost Sensor "B" Circuit Range / Performance
diff. pressure in front of throttle to average value of all pressure sensors @ start < -6.00[kPa] or > 6.00[kPa]
with engine shut-offtime> 5.0 [s] & engine speed <300 [rpm]
or
diff. boost pressure signal vs. barometric sensor signal >23.00 [kPa] or <-23.00 [kPa]
with engine speed <1000 [rpm] & throttle position <5.00 [%]
Check the Charge air pressure sensor 2 - G447- .
Check the charge air system and intake system for leaks. (I'd check wastegates and Bypass valves too.)
The Charge air pressure sensor 2 - G447- is located in the inlet to the intake manifold. The Engine Control Module - J623- uses the sensors signal to regulate the charge air pressure. There is no substitute function in the event of signal failure. Charge air
pressure regulation is shut off, leading to a significant reduction in engine output.
Fuses OK.
Battery voltage OK
Switch OFF all and electronic accessories.
Vehicles with Auto. Transmission, ensure Selector Lever position is in P.
Vehicles with Manual Transmission, ensure Gear Shift Lever position is in N with Parking Brake applied.
Coolant Temperature: ≥ 80 °C.
DISCONNECT: Charge air pressure sensor 2- G447- connector
IGNITION: ON
CHECK: Charge air pressure sensor 2 - G447-wiring connector terminals 1 to 3 for voltage
SPECIFIED VALUE: About 5.0 V
IGNITION: OFF
(All other tests require ECM removal.)
If I didn't find any obvious wiring issues I'd probably just replace it.
038906051K
https://www.ecstuning.com/b-genuine-...ns/038906051k/
Also check N75 valve and wiring that is the only thing I can think of that may be reflected in the generic P0045 code even though it is really called "Wastegate Bypass Regulator Valve".
