I've got a 2004 B6 S4, and ever since I got it the power steering didn't work at idle, but did okay if the revs were at 1500rpm or more. Finally the other day all of a sudden while driving, the power steering went completely dead and the pump is SCREAMING. The fluid looks old and black, smells almost burnt like, and is full of metal shaving glitter. Its safe to say the pump is dead. I did find in another post to make sure the lines are okay and they are, absolutely no visible leaks anywhere under the car no matter how long I let it sit and idle, even pumping the wheel back and fourth. I have some questions and need some help.
I scored a used pump with warranty for 100$ on eBay, just the pump. I know roughly where the pump is located, driver side of the engine towards the back under the header, I believe its shaft driven off the timing chain if I'm not mistaken. I cant find much of any information anywhere on how to go about accessing it and replacing it. What needs to come off, what's the easiest way to get to it and remove it, what will I need? Mind you, ill be doing this in my driveway on jack stands. Like any DIY mechanic, I want the most simple and efficient way to get to it. Removal and reinstallation. I've flushed the system the best I could while the old one is still on, to hopefully clean the rack out, I've heard some say the rack may need replacing but I doubt it will come to that, the rack feels fine no dead spots or anything, I've flushed the system to the point of nearly completely clean fluid. no luck, still screaming and no power steering. Anybody have any helpful links, videos, or advice? Really haven't found ANYTHING about removal of the pump, just location, and line replacement, not the whole pump. Its Tuesday night now and Ill be driving the car to and from work until Friday when it arrives, and Ill be starting on it as soon as the pump is in my hands. Really not thrilled with the lack of information, and with the location I know it will be an intrusive job no matter how I slice it. Pictures would be very helpful, by nature I am a visual learner. This is all so crazy to me considering my car has just over 100k miles. thanks so much in advance! hoping for as much info as possible by Friday.
