Results 1 to 22 of 22
    Sep 12 2020
    SC
    RS3 downpipe advice needed
    Looking at getting a downpipe, main reason is I'm wanting a better sounding exhaust. I'm thinking this will give me what I want + a little power boost versus an expensive catback.
    Currently DS1 tuned w/ all the supporting mods so I assume WG rattle wont be an issue
    No emissions checks in my state
    1) Benefits of Catted vs catless? (Aside from environment)
    2) Which brands are preferred? currently looking at an APR catless
    3) any other thoughts/advice/experience?
    Thanks
    Registered User Two Rings
    Sep 01 2021
    Branford / CT
    Hey, I just wanted to introduce myself to help you modify your vehicle quickly and efficiently.
    We have a few downpipes for you RS3 from 034MOTORSPORT, UNITRONIC, and Scorpion
    Free feel to reach out with any questions. I will provide you with links below
    https://xlr8performance.com/i-73639-...Rs3%2Bdownpipe
    https://xlr8performance.com/i-73792-...Rs3%2Bdownpipe
    https://xlr8performance.com/i-72232-...Rs3%2Bdownpipe
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    1) Benefits of Catted vs catless? (Aside from environment) - No, a few more hp with catless
    2) Which brands are preferred? currently looking at an APR catless - no, they all do the same job
    3) any other thoughts/advice/experience? - if you leave in your stock catted midpipes the smell wont be to bad if you go catless DP. Also get the DP ceramic coated before install
    Stage 1 more than you RS3
    Dec 02 2020
    Austin, TX
    My only complaint with going catless is the smell. If you just want a better sounding exhaust without having to do the downpipe and mid pipes, i recommend the Boost Logic Titanium exhaust. In my opinion, hands down the best sounding exhaust on the market for this platform.
    Veteran Member Three Rings signde's Avatar
    Apr 07 2019
    nashville, tn
    can you even find an APR downpipe for sale? APR discontinued stage 2 last year and my understanding is they were no longer making downpipes. i also seem to recall all remaining inventory sold out pretty fast after that.
    Audi 8V RS3 | Porsche 997.1 Turbo | VW MK4 R32 | Porsche Macan Turbo
    Stage 2 Banner Advertiser Three Rings Brian@Unitronic's Avatar
    Jan 11 2019
    PA
    I would highly recommend our downpipe! They should be back in stock towards the end of this month and I can assure you no other manufacturer has put as much engineering into a downpipe as we have.
    With our downpipe you will have a deeper tone than stock and no "tinny" sound like you'd get from thin wall stainless downpipes.
    https://www.getunitronic.com/parts/e...5tfsi-downpipe
    Let me know if you have any questions
    Brian
    UNITRONIC — Performance Software & Hardware for your VW® /Audi® / Porsche®
    Web: GetUNITRONIC.com | Tel: (866) 341-2447
    Follow us on: Facebook | Instagram | Twitter
    Feb 13 2021
    UK
    As Brian said cast downpipes definitely have a richer/better sound to them at part throttle acceleration. Was quite noticeable hearing one on a friends car after running a milltek de-cat on my own for a year - which is not a bad sound, but is a bit high pitched under part throttle tip in acceleration. Waste gate rattle was horrific with my setup, so if a tune does not address that, it's well worth going cast and catted.
    Not sure if I'd go de-catted if I had it to do again, sooty tailpipes, a bit of smell and not a lot of gains in power, plus relying on one shop to sneak me though inspections here. Though I do wonder if EGT (exhaust gas temperatures) are a factor to consider?
    Sep 12 2020
    SC
    Quote Originally Posted by ArrEssDrei View Post
    Thanks for the info, I'll def ensure its cast.
    Thats what I like about the APR, you can get their high flow catted midpipes if the smell, soot, etc is too bad, or remove them and remain straight catless. Swapping a downpipe is not nearly as easy ofc.
    Quote Originally Posted by signde View Post
    yes, you can get them used
    Quote Originally Posted by Brian@Unitronic View Post
    Brian
    Thanks Brian, How does catless compare to catted in terms of sound?
    Senior Member Three Rings 8STTRS's Avatar
    Jul 28 2021
    Navarre, Florida
    Quote Originally Posted by Arelax View Post
    I'm not Brian, sorry but, in my experience, when you compare aftermarket headers or downpipes that are with and without cats, within the same brand, the difference is slightly more volume for a catless system. Of course, they are all significantly louder than the stock setup but, a high flow cat is not quiet by any means whatsoever.
    2018 Audi TT RS
    JDY Next Gen 6670 coming soon (shooting for 975-1kwhp on low boost).
    Apr 14 2014
    '24 RS3 // '14 S4
    MD
    I have a Redstar Exhaust downpipe on my TTRS and love it. I will be getting their downpipe for my RS3 once I am ready to swap it out. Fit and finish are awesome and they have great support.
    https://redstarexhaustusa.com/audi/2...-downpipe.html
    Veteran Member Three Rings jd_rs3's Avatar
    Dec 18 2018
    Longmont, CO
    I highly recommend e85 if going catless DP. The smell is horrible on 91/93. Your clothing and hair will smell like hydrocarbons until washed if you are anywhere near your car while it's running. It's at least tolerable with e85.
    2018 nardo gray rs3 - sold
    Sep 27 2020
    Livermore,CA
    Smell is an often overlooked part. Even driving behind a catless car is annoying. The hp difference doesn't add up till you get till like built motor territory. And at that point, you don't care as much.
    As stated above they will sound different too. Like how the midpipes change the sound, the cat in the dp will have a similar effect
    Sent from my SM-G960U using Tapatalk
    Established Member Two Rings nate.co's Avatar
    May 03 2019
    Colorado
    Here's some video - this is a Unitronic catted downpipe and midpipes. Stage 2 tune, 91 octane, IE intake and Unitronic intercooler. I highly highly highly recommend the catted setup, cars have catalytic converters for very good reasons. The car is fast as hell.
    Microphone is mounted on the trunk, video is a GoPro suction cupped to the sunroof.
    RS3 2019 Mythos Black - DS1 flex fuel stage 2 🔥🔥
    Sep 12 2020
    SC
    Quote Originally Posted by nate.co View Post
    thanks for that.
    We have very similar radar/blackvue setups too. and i appreciate the tip on go pro mounting location. Is there an extension on the suction mount? and what microphone you using?
    Senior Member Two Rings WmRS3's Avatar
    Dec 13 2019
    Audi RS3, Audi S8, Ford Raptor, Volvo S60R
    MA
    thanks for that.
    I use same setup for all my street testing and races for years. I use go pro cup with a long red 8 in alum extension arm off ebay and an ebay mic with noise sock I mount it on outside of trunk with a little painters tape.
    https://www.youtube.com/watch?v=BsycwqAXfGQ
    May 03 2019
    Colorado
    thanks for that.
    Yeah, love that dashcam.
    I just use a GoPro suction cup with an extension, can't remember where I got it, probably Amazon. Mic is a Rode Stereo VideoMic X (which is overkill here but a nice mic) on the same type suction cup with without the long extension.
    Senior Member Two Rings itr325's Avatar
    Mar 13 2007
    1998 Acura Integra Type-R
    Milwaukee/Wisconsin
    Quote Originally Posted by jd_rs3 View Post
    I’m catless and run E85 in summer and 93 in winter, I’ve never had my clothes smell. This is a bit of an exaggeration. That’s not to say there isn’t a little smell of un-burnt fuel, but it’s not awful.
    Dec 18 2018
    Longmont, CO
    Agree to disagree then. 91 octane and catless DP is obnoxious if you stand near the car while running. And if you start the car in the garage, it will stink even worse.
    Also never really understood the whole "I run 91 in the winter" argument but that's a different discussion.
    Sent from my Pixel 4a using Tapatalk
    Sep 27 2020
    Livermore,CA
    E85 has starting issues in colder weather. That and fuel blends end up being lower quality e85 like e60ish
    Mar 09 2018
    2018 RS3
    Quote Originally Posted by brobst View Post
    Yeah, cold start on high E content can be a pain but can be done. Ethanol content is the same all year in California (+E80) according to Pearson and Propel fuels.
    E60 is a breeze if tuned correctly...
    I've tuned a few Subaru's and I've managed to them to start up in the winter...but these are California bay area winters lol
    I'm fairly confident they will crank over without too much effort in freezing temps.
    Florett RS3+DS1+034TCU
    Sep 27 2020
    Livermore,CA
    Just for reference. Also e85 absorbs moisture which is a bigger issue in the winter
    afdc.energy.gov
    Like gasoline and diesel fuel, E85 and other ethanol-gasoline blends are adjusted seasonally and geographically to ensure proper starting and performance. For example, E85 sold during colder months often contains lower levels of ethanol to produce the vapor pressure necessary for starting in cold temperatures. For this reason, fueling site operators offering ethanol blends typically cannot carry over summer-blend E85 into the winter months. They must instead "blend down" any remaining summer fuel to meet the ASTM specification's requirements for winter temperature conditions.
    Junior Member Two Rings
    Feb 04 2020
    2019 RS3
    PA
    I was in the same boat as you. Historically, I had a catless on my prior EVO X and it smelt terrible. Almost to the point where I was embarrassed. Im also in an area that does not do emission testing. Further more, I have heard feedback that many DPs have noisy wastegate rattle which is debatable with each persons opinion of "noisy" different. I had a difficult time paying an extra $1k for the Uni since my wife questions every car expenditure :( I have no intentions of ever going past a hybrid turbo and decided on the Uni. No regrets and it's been on for almost a year now. Very little rattle which is only barely noticeable when the windows are down and im near a barrier. Absolutely no smell and no worries of ever being fined for not having a cat.
