P1
P2
P3
P4
P5
P6
This is not a DIY but will give some general guidance
Materials:
• Wet/Dry Sandpaper kit with 120/150 to 2500 grit
• Composite Envisions Two Part Resin Epoxy – Epoxy Resin (1159A) and Hardener (1160B), measuring cups, high quality bristle brush applicators (low quality brushes will shed) or some rubber tipped epoxy resin applicator wands from AMZN).
The step by step, detailed instructions for mixing and applying the resin is included in the Composite Envisions kit.
• Kitchen scale for measuring resin mix
• Razor Blade
• Vinyl decals for RS Logo (Red) and V8 – 4.2 FSI (I can print these)
• High Quality Clear Coat with UV and High Temp Protection (you get what you pay for here. If you cheap out you’ll suffer.) – I used Eastwood 2K AERO-SPRAY High Glass Clear.
• Compound / Polish applied with a DA tool. Compounding and polishing by hand is slow and not as effective.
• Optional: Ceramic Coating
Process:
1. Remove failed resin coat from covers. PIC 2 The Audi factory applied resin is what fails on these and ultimately renders them trash. Slip a razor blade under a peeling edge and you can gradually see that the resin will come off in sheets. Same thing with the rings and RS logo. The rings have 4 little locator protrusions underneath that fit into the cover itself. These will most likely break but you can usually salvage 2 of the 4 locators. The RS logo is secured with double sided tape. Take measurements or make a template of where these are centered on the main cover so you can apply them in the same general location towards the end of the job.
2. Sand: You’ll need to sand the hell out of the remaining old, crusty, yellowed resin that’s left behind. Start dry sanding with 120 or 150 until it the yellow is gone. You’ll be able to remove 99% of it and the remaining yellowing trapped will hardly be noticeable in the end. You’re going for the results shown in PIC 4
3. Wet sand: Next is just a combo of wet/dry sanding up the grit chain from 220, 280, 360, 400 and 800 until it feels smooth to the touch.
4. Decal: V8 – 4.2 FSI Apply to the smaller cover.
5. Resin: Apply epoxy resin coats according to the manufacturer’s instructions.
6. Sand: Flatten the cured resin by wet sanding up the chain again but only start with grit in the 400 to 600 range and work it up to 1200.
7. Prep: the surface for clear coat by rinsing with water and using a wax/grease remover.
8. Paint: Clear coat according to manufacturer’s instructions.
9. Sand: Final wet sand the clear coat from 1000 up to 2500.
10. Compound
11. Polish
12. Optional: Ceramic Coating
13. Rings and RS emblems can be secured in place with the epoxy resin. Apply sparingly (little dab will do ya) to the underside. Too much and the epoxy may squeeze out from underneath and onto the clear coat. I would avoid using super glues/gorilla glue or similar as I don’t think those will hold up to the heat cycles experienced under the hood.
