Originally Posted by
Audihead12
Hi Guys,
I am looking to purchase a 2016 Audi s3(pre facelift) and I just wondering,
are these newer audi's and I guess newer european cars still susceptible to excessive oil consumption? my old 335i used to drink oil like crazy.
also are Audi s3's generally pretty reliable? I heard the early models had turbo failures, did they fix that from 2016 ?
I ask because I want to do abit of road tripping in the future and I guess you could say I am a bit traumatised by my old 335i being so unreliable and drinking so much bloody oil that I had to keep a litre in the boot incase i got into trouble.
are newer european cars kind of getting a bit more reliable ?
Thanks in advance.
Reliable...My 2004 Audi A4 1.8t was reliable! Well over 100,000 miles with zero issues.
The S3 is a different animal....a VW? MQB platform. An expensive Volkswagen...
The gearbox needs its oil changed every 40,000 miles. Unless you have the newer 7-speed which oil gets changed every 80,000.
The rear Haldex needs its oil changed every 3 years...reguard less of miles. Use to be every 40,000...but VW changed it...
The engine has allot of plastic parts...water pump...thermostat housing...radiator...intercooler...
The fuel injectors have been updated by VW/Audi over a dozen times...as have allot of other parts.
The plastic PVC directs oil fumes back into the engine and they stick onto the intake valves...so the engine needs carbon cleaning...say every 50,000 miles...
Theres a PODS/Airbag recall that to this day Audi has not fixed....
Reliable....compared to what? My last Audi...No.
Compared to other cars of similar build???
Plus your in
Australia...so these cars can differ from country to country.
Here in the USA ours do not have the second set of injectors(port) in the intake manifold...which helps reduce the carbon build up.
Mine uses oil. I suspect its the turbo hot side bearing and seal wear...
I bought new replacement turbo...
The very expensive electronic shocks dont last...mainly the fronts.
The oil pan is plastic....
The Bevel box holds 1 quart of oil...and makes noise after many miles..
