As you can tell by the photo, the car is about 2 degrees off on the driver side. Not only can you visually see the problem, but ive had the car aligned twice (once by an indy shop, then at the dealer) to confirm.
When I had the car on the rack at the first shop, the mechanic and I were going over the underside of the car. Nothing looks wrong or out of place. Both side suspension setups look identical in terms of age and use. No bushings are shot, I hear no sounds while driving.
The car doesn't pull, the Camber and Toe are in spec and perfectly fine.
The car spent about a week at Audi. They tech first put it on the alignment rack, preformed a normal wheel alignment, and confirmed that the caster is 2 degrees off. He too, agreed that the car doesn't look like anything is bent or out of the ordinary. No scrapes on the belly pans, very light scratching on the lower control arm, but "didn't look like that could be the problem. He recommended me to go to a body shop and check to make sure the frame was straight. Now, im feeling discouraged with the car. While visually on the outside I can tell no body panels have been replaced to indicate that maybe there was an accident that wasn't on the CarFax. Im a BIT OCD so when I look at the car I can visually see the problem, and I worry that in the future with a wider wheel and tire setup, that the scrub radius could be affected and would cause rubbing.
My assumption, the previous owner Hit a curb in a parking lot, or a parking block and bent something so slightly that it caused the caster to shift, or possibly even the subframe shifted upon "impact".
The main questions:
What would you do? I bought the car about 2 months ago.
I know that B8s had a subframe alignment tool that could shift the subframe for an alignment, but I was told by the audi guys that that was only for camber, but I believe it can help with caster too.
Would 034 Upper control arms adjust caster like the SPC arms claim to do. I wouldn't worry if it were less than a degree off, but 2 is a bit much for me..
Any insight, thoughts, or opinions would be greatly appreciated.
