Page 1 of 3 123 LastLast
Results 1 to 40 of 101
    Stage 2 Banner Advertiser Four Rings Arin@APR's Avatar
    Aug 23 2008
    Auburn, AL
    APR SQ7 and SQ8 ECU Upgrades offer significant horsepower and torque gains!
    http://goapr.io/40sq
    We're excited to announce our Engine Control Unit (ECU) Upgrades are now available for the Audi SQ7 and SQ8 4.0 TFSI V8 engine with the Bosch MG1 ECU! Expect massive gains with up to 685-767 HP and 731-804 FT-LBS of torque on tap, depending on octane, from this simple software upgrade.
    APR's ECU Upgrades are the best dollar-per-horsepower modification one can make to improve engine performance. The upgrades dramatically increase horsepower and torque, making for an exceptionally quicker and more exciting vehicle. This is made possible through APR's optimization of the factory engine management system to take full advantage of the engine's capabilities, without needing any end user adjustment. The ECU Upgrades are available with various features and supported octane levels and each stage is compatible with most typical bolt-on modifications. The software is installed to the vehicle's factory ECU through the OBD-II port once the ECU is unlocked, resulting in a clean and headache-free install. Furthermore, for those looking for tuning with a limited powertrain warranty, APR Plus has you covered!
    More dynos on our website:
    Features and Benefits
    • Delivers up to 685-767 HP with 731-804 FT-LBS depending on octane
    • Max gains of +191-262 AWHP and +163-268 AWFT-LBS depending on octane
    • Supports 91 AKI, 93 AKI, 100 AKI, and 104 AKI fuel grades
    • Optional factory term limit matching limited powertrain warranty with APR Plus
    • Quicker and Faster: [email protected] MPH (Stock) [email protected] MPH (APR Stage 1 93)
    • Speed limiter removed
    • Standing RPM soft limiter increased
    • Left-foot braking / brake boosting added
    • Properly rescaled performance gauges
    • Optimized thermal management and protection
    • Optimized launch control strategy for faster response
    • Optimized driveline protection during launch
    • No hardware required (Software only)
    • Supports standard bolt on modifications
    • Eliminated the need for a TCU upgrade to achieve full torque
    • Free lifetime updates
    • Direct OBDII port flash (No ECU removal)
    • 30 day money back guarantee
    GoAPR.com | Facebook | YouTube | Twitter | Instagram
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    Oct 26 2016
    Orange County CA
    Quote Originally Posted by Arin@APR View Post
    Awesome! Any videos yet? Any changes to the exhaust sound?
    Aug 23 2008
    Auburn, AL
    The car is back in our good customers hands. Exhaust during normal driving is the same. But when you get on it, the system is working harder, moving more air, so the tone may increase. It's not going to be the same as doing a new exhaust though, but better than stock in my opinion.
    Oct 26 2016
    Orange County CA
    That is great. Flash time the usual 5-10 minutes on average?
    Aug 23 2008
    Auburn, AL
    It's usually longer than that with clearing codes after the flash and such.
    Dec 21 2020
    Michigan
    So the SQ8 and RSQ8 have the same exact HP/TQ after an APR 93 tune?
    Both at 710HP 751TQ
    I thought the RSQ8 had bigger turbos stock
    Aug 23 2008
    Auburn, AL
    We achieved the same power on both vehicles after tuning.
    Sep 06 2021
    New York
    Nice job. I hope someone takes the plunge here and can provide a review. I had installed a Weistec tune on my old Q8 and was not happy with the amount of transmission slippage. Can you guys tell me if that is common and would happen if I tune my SQ7?
    Aug 23 2008
    Auburn, AL
    You shouldn't see any transmission slippage. You won't with our tunes.
    Dec 28 2005
    NY/NJ
    11 sec 1/4mi SQ7 .. APR tune?
    Current: 2024 SQ7, 2021 RS5
    Aug 23 2008
    Auburn, AL
    Yes. Customer is in Florida.
    Junior Member One Ring
    Oct 20 2021
    Delaware DE
    Is this tune available for 2022 sq7 ?
    Aug 23 2008
    Auburn, AL
    Probably not. The latest batch of ECUs, typically with a build date after mid 2021 on the ECU, are coming in locked with a new security protocol we need to work around. This applies to most all platforms with a VAG Bosch MG1 ECU. One we get past that we'll make an announcement.
    Oct 26 2016
    Orange County CA
    How do you switch between maps?
    Oct 26 2016
    Orange County CA
    And also, what is soft limited supposed to be raised to?
    Aug 23 2008
    Auburn, AL
    Quote Originally Posted by martinitime View Post
    Reflash at a dealer.
    It's raised up so you can rev it at park/neutral to around redline.
    Oct 26 2016
    Orange County CA
    I just installed the tune yesterday. Amazing gains but won’t rev past 4K in Park/Neutral etc…
    Any plans to update map switching on the fly? Tough to go from 104 octane back to pump gas or vice versa while needing to stop at the dealer/shop to flash.
    Aug 23 2008
    Auburn, AL
    Shoot me your vin. I'll see if we can get that bumped up. May be different on your ECU.
    We don't have any plans at the moment. Perhaps a different switching method in the future, but I can't promise anything right now or speculate on timing.
    Oct 20 2021
    Delaware DE
    On your website I have an option to select 2022 for the ecu tune so does that one there's a tune available for My 2022 sq7 ?
    Aug 23 2008
    Auburn, AL
    The application guide on our website will always lag what's available, but in this case, we don't have a solution (most likely). Most of the late 2021 ECUs were locked, so I'd expect the same on new models. We need to figure that out before we can offer software.
    Mar 24 2022
    IL
    Care to go into details on mods? Feel free to PM me.
    Veteran Member Three Rings greg@dubaudi's Avatar
    Feb 05 2005
    2001.5 pearl WB Avant, 2016 SQ5
    Alton Bay, NH
    Real tempted to pull the trigger on this. Wife’s car but man do i love it.
    2001.5 EPL/Tial 770 Pearl WB Avant///2021 SQ7 Nimbus Grey///2021 GMC 3500 Duramax
    Aug 23 2008
    Auburn, AL
    She'll love it too :)
    Feb 05 2005
    Alton Bay, NH
    With a APR tune and if I add downpipes will I get a cell if they're missing some cells
    Aug 23 2008
    Auburn, AL
    If it doesn't pass the onboard test, it will display a CEL.
    Feb 05 2005
    Alton Bay, NH
    My 2021 is doing same thing after APR tune. Hits soft limiter and thats it. Tune is very impressive when driving. Highly recommend to anyone on the fence.
    Jun 05 2022
    2020 SQ7 2012 Porsche Cayenne Turbo
    Colorado
    Very nice results!!!
    This is why the RSQ8 is such a bad deal.
    Same everything motorwise to the SQ8.
    SQ8 or SQ7 with sport package plus APR tune= Voila
    Best buy
    Jun 05 2022
    Colorado
    Quote Originally Posted by 313RS7 View Post
    Both at 710HP 751TQ
    Nope....exactly the same motor.
    Jun 05 2022
    Colorado
    It's amazing how capable this engine is with just a tune.
    Must have a little bigger turbo because of the hybrid system reducing lag.
    Very impressive numbers without a turbo swap!!
    Jan 21 2020
    Is there any improvement in MPG with this tune.....when driving in normal (must resist hammering it) highway mode? I just picked up a 2021 SQ8. Also have a 2015 RS7.
    Aug 23 2008
    Auburn, AL
    When just cruising normally, we have customers all the time saying they get better MPG. But with me driving, no. I can't resist giving it the beans all the time.
    Oct 26 2016
    Orange County CA
    Is there a way to switch maps yet without reflashing?
    Junior Member Two Rings
    May 05 2011
    QUeens/NY
    2022 ECU still locked?
    Aug 23 2008
    Auburn, AL
    We've always had the ability to flash the new ECUs but getting the factory code off the ECU, which is necessary for tuning, has been a challenge. Sometimes we're able to get the file without needing the ECU in our hands. In those cases, like if there was a factory update, we're able to easily write software and flash the ECU.
    If you happen to know the code I can check to see if we have it. Here's how to get it: www.goapr.com/support/boxcode/
    Oct 26 2016
    Orange County CA
    Careful because this tune could cause this repair.
    Aug 23 2008
    Auburn, AL
    ok?
    Senior Member Three Rings b5rs4's Avatar
    Aug 30 2007
    bmw x5
    winter springs, fl
    About to pull the trigger on a 21 sq8...love most all comments except for the last one about turbo failure. Has anyone had a problem other then this person, because I'm super tempted right now and just want to make sure. Also does Apr have a tune for lowering the car, through air ride? Thanks in advance
    Sent from my SM-G975U using Tapatalk
    JHM 93, JHM Intake spacers, LWFW, K&N, 2.5 custom cat back, catless oem DPs all new gaskets and seals, new chains, guides, and tensioners,rebuilt heads new clutch and pressure plate, new a/c compressor and power steering pump and lines 034 motor mounts, Apikol snub, Vogland Coils, 19 Miro 111...almost back together
    Aug 23 2008
    Auburn, AL
    On the last generation 4.0T, turbo failure was common on higher mileage cars due to an oil issue, but nothing like that on this platform that I've seen. On our end, we take great care in our calibration to ensure we don't overspin the turbos.
    As for lowering, we're working on a product, but it's not ready yet. It's not something controlled by the ECU.
    Established Member Two Rings Dtomasi's Avatar
    Jan 04 2015
    06 BMW E60 M5 (My Fix)
    NoVA
    That's a pretty bold statement, care to elaborate?
    Oct 26 2016
    Orange County CA
    Quote Originally Posted by Dtomasi View Post
    Sure. Got an check engine light error that car wasn’t making correct boost. My car was flashed back to “stock” about 5 months ago as I was preparing for a factory recall on the mmi software.
    After the repair it was kept stock and then the check engine light came on. I checked the code and it was 34203 Boost pressure regulation P02999.
    Audi said they detected the tune and TD1 the vehicle. It will cost about $1900 to check a hose malfunction, another $1900 to recalibrate the front sensors when they put the front grill back on and if that doesn’t work, another 10k plus to replace the turbos.
    Does this help?
