Results 1 to 11 of 11
    Apr 21 2011
    las vegas
    0-60 on audi factory timing system...
    I'm curious what everyone has done on the factory timing system? I was bored tonight and was playing with the system.I have the MTM cantronic (so 722hp?) and 1/4 tank of gas, with launch control i did 3.8 sec 0-60...seems a little slow huh? considering i've read that these cars are supposed to do 3.2 stock? feedback anyone? times from other members?
    80 degrees outside currently in Las Vegas at midnight....
    DKM
    Junior Member Two Rings
    Apr 03 2016
    Hmm there has to be error somewhere. I did this last month using factory system prior to my tune and got either 3.3 or 3.4 I forget exact value
    Maybe you were going uphill?
    Aug 04 2021
    DFW
    Seems like that factory timing unit is usually 0.15-0.25 slower when compared to a draggy or one of the other widely used brands. Could be that the OEM timer doesn’t include the rollout in its calculation so that would explain most of the difference.
    Veteran Member Four Rings FBAnder's Avatar
    Mar 05 2020
    Chicago Metro
    Maybe that's why they pulled it.
    Oct 23 2020
    CA
    3.6s stock ... multiple times ... always the same. a bit uphill can make a difference, even if you dont notice its uphill a bit
    Established Member Two Rings allenyao09's Avatar
    Aug 18 2021
    21' Audi RS6 Avant, 23' Toyota Supra 3.0 MT, 08' Mitsubishi Evo X GSR
    I couldn't find the on board timing function on my RS6 thou. Checked the manual and it says "not available in all countries". I guess that's blocked in the US. How did you guys bring it up?
    Nov 21 2019
    Philly
    my car doesnt have the 0-60 activated, has anyone found it in vag-com. i think i found it but its checked ON ....
    Apr 21 2011
    las vegas
    I ended up doing a 3.6 0-60 but still seems slow...but in all fairness i'm in Las Vegas and its been a little warm and i did some runs before measuring 0-60.
    also curious that some people dont have this function activated. It does 0-60, 0-100(i think) 1/8 mile and 1/4mile times. its kinda fun to mess with. Maybe later delivery dates had its switched off. My car was delivered Dec 2020.
    DKM
    Apr 21 2011
    las vegas
    Quote Originally Posted by allenyao09 View Post
    Nope...my car is a US car.
    Mar 05 2020
    Chicago Metro
    I started a thread on this feature not long ago. Early US cars had it. Stopped being turned on out of the box around late December 20 or January 21 built cars. The thread has instructions on how to enable it.
    https://www.audizine.com/forum/showt...rements-Option
    Senior Member Two Rings OptimusModulus's Avatar
    May 29 2014
    Chicago, IL
    I got 3.6 on my first attempt last night...
    For OBD11/Vag-com:
    HOOD MUST BE POPPED
    Module 17 (dashboard/display)
    Adaptations
    "Configuration of displayable contents"
    "Acceleration measurement" - switch to active
    2024 Ascari []RS6 Performance
    2021 Nardo []RS6 (Sold)
    2013 Ibis White []S5 6MT (Sold)
    “Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.” -- Jeremy Clarkson
