    Veteran Member Four Rings bluetori's Avatar
    Jan 14 2010
    Discovery 4, RR7, SP Fireblade
    Georgia
    A5 steering wheel
    My B8 is showing some age in the interior department and to top it off my interior is Gray. I was wondering for the gurus if they knew if this wheel would fit. Or is there a certain era that mounts without issue?
    https://www.ebay.com/itm/13-17-AUDI-...-127632-2357-0
    Veteran Member Four Rings MyDimeIsUp's Avatar
    Dec 04 2019
    West Chester, PA
    That'll work just fine. Some on the A4 came with 3-spoke optioned from factory
    2020 BMW M340i xDrive - Mineral Grey
    2012 Audi A6 3.0T Prestige - 034 Stage 1 ECU and TCU | CTS Turbo Intake | 034 Street Density Motor Mounts w/ JHM Trans Insert | ECS X-Pipe
    2013 Audi allroad - RIP
    2007 Toyota corolla
    Jan 14 2010
    Georgia
    Is it basically the airbag connection that I have to watch for?
    Jul 16 2018
    Atlanta
    That's a B8.5 wheel. It uses a round airbag rather than the trapezoidal airbag of the B8.5. So you're needing a new airbag for the new wheel. The airbag harness should be the same green tab plug on the coil spring side, the airbag harness will be specific to the airbag on the airbag side. For that wheel, the airbag would be 8K0 880 201 AE AZ3, replaced by 8K0 880 201 AR AZ3 (the AZ3 is the steel grey color code for the airbag cover). The airbag harness to use with that airbag in this application would be 8U0 971 589 J, if the airbag doesn't have it with it (new airbags include the harness).
    Replacing the wheel introduces numerous decisions that must be made to conclude a specific part number to look for:
    round vs trapezoid airbag
    3-spoke vs 4-spoke
    round vs flat bottom, if 3-spoke wheel and round airbag
    with vs without paddles, if automatic trans
    wheel leather color
    B8.0 vs B8.5 button style
    bottom spoke style and badging, if 3-spoke
    On that color item, note that B8.0 grey is agate grey and B8.5 grey is steel grey. Doubt it'd be an issue, but I point it out.
    BTW, the A4 and the A5 coupe shared wheels, that wheel is the same one that would have been used on an equally configured B8.5 A4.
    Jan 14 2010
    Georgia
    Yeah I was aware of the round airbag that was what I was wanting to have. I have been looking for a matching airbag but Gray is not a common colour for parts.
