one thing I saw myself is that b8.5s have an "upgraded" smaller oil pump while b8s use bigger oil pump from 3.2fsi engine. Both are variable mode oil pumps which switch between "high" and "low" oil pressure at some rpms. b8s have somewhat higher "low" pressure along with higher redline. Different head bolts and camshafts - b8s usually have special cutouts on the camshafts to allow head bolt removal without removing the camshafts and cam girdles. Cam shaft adjusters are slightly different, probably non-functional difference though but do need different tools to hold them when unbolting from the camshafts. Slightly different crankcase pressures (different PCVs as mentioned). What else - I think b8.5 alternators are held by studs, not bolts, but that doesn't change any function or part compatibility.
As for the dsgs, lots of gen2 parts are actually the updates for the gen1 like the front clutch cover plate, the clutch itself and oil pump. B8.5 dsg has a larger gear ratio spread, I think it's like 7 or something like that. of course, the software is different, probably so it doesn't kill itself while it's still young.
