Curious to see who all has replaced their thermostat and at what mileage. Also would like to know what symptoms you experienced when it failed.
I've read a few instances of people having them fail pretty early on (15-18k miles) and I think I may be headed that direction as well, 20k on the clock. 2018 SQ5.
Still trying to figure out how to diagnose the thermostat.
They symptoms I have experienced 3 times now:
-A/C Luke Cold. Not ice cold, not ambient. Just a bit cool instead of cold.
-Fans running at 100%
-Taking a long time to warm up (oil temp <190* for 20 miles / 40 minutes of driving)
-Coolant Gauge showing 1 tick below middle (where it always seems to be at the middle normally)
-Reduced fuel mileage on the dash (when the symptoms are presenting themselves, like the car thinks it's cold still)
Problem being it has happened totally randomly and I cannot seem to reproduce it on demand. I'm getting no codes and not overheating. Car drives normally, other than the symptoms I listed above. Each time it has cleared itself and been normal after 3-4 restarts.
Another possible piece of the puzzle: It has only happened since I've flashed 034's Stage 1 tune. I have seen 2-3 people say there is a fan issue with the 034 tune on certain box codes. Unfortunately, I cannot find a definitive answer if all these symptoms are indictive of the "fan issue" with the tune or if the thermostat is the cause of the fan issue in my case.
I could flash back to stock and wait for it to happen again, or not happen again, sadly it has happened so randomly already that I have no clue how long it would take to pop up again. Issue I have with this, I've been running the E85 tune and would have to run my current tank down as far as possible and fill with Premium before flashing back to stock. I don't really want to drive the vehicle extendedly if the thermostat is failing. Afraid it will stick closed and leave me stranded somewhere. Stuck open wouldn't be a huge issue, thinking this is what it has done these 3 times already?
Thoughts? Experiences?
