Anyway, progress so far.. I picked up the car August 15th from Nathan with a Uhaul truck and auto transport and backed it into my garage (because the transmission only does reverse).
The next day I managed to get the Cat-back off, front clip of the car off (or hanging by ac lines), and started working on getting all the CV shafts and Driveshaft out. Had a crazy amount of trouble with the rear CVs and Driveshaft. They just didn't want to let go of the diff, but heat and an air hammer eventually convinced them.
The cat back is definitely not going back on the car..
Few more things out of the way like the suspension, coolant hoses, etc. and the engine was ready to come out
The V8 looks so ridiculous next to my Fulvia..
Engine is pretty dirty so now I have the intake off, and the valley pan out to clean everything up. Also was recommended that I check flatness on the valley cover so I sanded it with 400 and 600 on a piece of countertop that I was able to borrow and checked it with guide coat.
Seeing quite a bit of carbon build up, but I'm thinking it may be because the PCV has failed in the open position.. Nothing a little mineral spirits can't fix
Also cracked open the intake manifold to give it a good clean, but unsure how the shafts come out after removing the small bolt at the end of the shaft.. It seemed it would just slide out the other end at this point but everything seems well fixed to the shaft and I don't want to break anything.
Finger pointing to the bolt that was removed that I thought would allow shaft removal
Anyway, that's the progress so far. A little more teardown to do in order to get to the tensioner shoes, but hoping to get all the parts I need for the engine on order this week or early next.
