Results 1 to 12 of 12
    Junior Member Two Rings
    Jul 30 2021
    Quebec
    Can't open hood. Latch too stiff to pull
    Hi everyone!
    So, I'm having a kinda difficult time with my car right now. Last week, I tried to open my hood by pulling the lever inside the car (with the drive door open, in case anyone asks), and it was so hard to pull that I literally snapped the handle. I ordered a new one and replaced everything, but it's still to hard to pull that I will certainly break it again If I pull it too hard. Right now, I have no idea how to open my stupid hood just to fill my windshield washer tank. The cable seems "stuck". It moves like a 1/2 inch but after that it's stuck. Weirdly, one day it works perfectly find but the other it's stuck.
    Do you have any idea on what to do?
    Veteran Member Four Rings b8audis4's Avatar
    Nov 06 2013
    Ohio
    This happened to me after the dealer did the carbon cleaning. I believe they didn’t attach something correctly and it was binding. After using it more it seemed to get back closer to normal but still not 100%.
    I later had an issue where the latch (safety mechanism) on the hood itself wouldn’t release properly, causing me to be unable to open the hood. My local shop disassembled everything and cleaned it and it seemed to work fine after that. I’d also recommend greasing the latch assembly located near the radiator as well to see if that helps.
    2011 Audi S4 - Ibis - Magma - Premium Plus - XPEL - STIR PLUS - Anti Laser Priority - AWE Resonated Exhaust - Ecodes - Alu Kruez - BBS CH-R (Mops)
    Established Member Two Rings Mfryman1's Avatar
    Jun 28 2020
    Pharr texas
    Spray the exposed cable ends with a good P-oil also and the latch Mech. that the latches onto. Also put a little grease on the "U" shaped latch that goes into the latch. Also there is a connection point about 1 foot away from the Drivers side headlight where the cable can be disconnected if you were going to remove the front end for service. This is also a place to spray the P-oil and lube abd check for obvious kinks where the ball socket fits together there. See circle with arrow.
    2012 white S4
    Senior Member Four Rings
    Jun 08 2021
    PA
    Have somebody put downward pressure on the hood in the latch area. Sometimes it helps
    Jul 30 2021
    Quebec
    These are all very good recommendations... the only thing is that I literally cannot open the hood. Is there a way to open it from under the car ? I can't see any way to open it except from cutting the mechanism
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Quote Originally Posted by spark365 View Post
    A simple search revealed these (and more) threads on resolution of a failure to release the hood. One of them should guide you to a solution ...
    https://www.audizine.com/forum/showt...se-lever-stuck
    https://www.audizine.com/forum/showt...784-Hood-cable
    https://www.audizine.com/forum/showt...cted-or-broken
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Jul 30 2021
    Quebec
    Well, my last option would be the "remove fender liner" trick. I will try it and see if it works.
    Jul 30 2021
    Quebec
    Well found out that my hood was slightly misaligned, causing the mechanism to lock. I hammered the hook on the hood slightly and now everything is fine.
    Jul 18 2010
    NE Ohio
    Thanks for the update! Did you remove the fender liner to get it opened so that you could "realign" the latching hook? Hopefully it won't give you any more problems.
    Jul 30 2021
    Quebec
    No! Actually my father wiggled it while I pulled on the latch and it released. Just pushing or pulling on the hood wasn't enough. I was on the fence of dismantling the fender line but I was glad I didn't have to
    Jul 18 2010
    NE Ohio
    Excellent! Good to hear it was an easy and inexpensive fix. In addition to straightening out the latching hook, it might be advisable to apply a bit of lubrication to the latching mechanism. According to the official Audi Scheduled Maintenance Intervals for the 2011 model year, at 55K/115K/175K Kilometers, in the "Doors" category, it calls for lubricating the door hinges, straps, locks and hood latch. If you haven't lubed it lately, it might also help the hood to pop up (more readily) when the inside release is pulled.
    Thanks again for the confirmation of the fix!
    Jul 30 2021
    Quebec
    First thing I did was lubricating it of course, but really, the misaligned hook was the only reason it was stuck in the first place.
