Results 1 to 40 of 40
    Deactivated Two Rings
    Nov 11 2020
    Lake Tahoe, CA
    Anybody upgrade their atmospheric dump valve/diverter valve?
    Stumbled upon the Forge Motorsport valve and wondered if anybody has installed one? Does it make any difference other than noise?
    Veteran Member Four Rings SHCKR's Avatar
    Jan 03 2019
    '19 Subaru Ascent
    NC
    Quote Originally Posted by Sierra Audi View Post
    Don't. Too many horror stories
    '18 S4 Prestige; all packages
    Jul 12 2016
    Gardiner/NY/US
    Interested in this as well. I’m fairly certain I need a new Diverter Valve anyways… Was curious if the Forge was worth the money.
    B9 S5 SB - IE ECU/TCU Stage III - IE FMIC
    AWE Touring Exhaust - Roc Euro Intake
    Pure750 - IE Turbo Inlet - 034 HPFP
    Nov 11 2020
    Lake Tahoe, CA
    Was just doing some studying regarding these and most articles state that they are beneficial in if you are tuned with increased boost and experiencing flutter which I am. Curious as to why they might produce problems?
    Veteran Member Three Rings kifac's Avatar
    Mar 24 2014
    Mississauga
    Yeah ive also heard stories of DV just causing issues.
    Car doesnt seem to like it at all.
    Its a hit or miss.
    Some people run it fine and others just cant get it to work.
    Senior Member Three Rings Valentino S5's Avatar
    May 26 2019
    Mexico City
    Quote Originally Posted by SHCKR View Post
    What he said. That Forge valve is detrimental to the performance of our cars. Many of us went that way and regret to do it. The OEM recirculating valve is the best way to go, by far (even if you are tuned, it works perfect).
    2019 S5 Coupe Mythos Black. EPL Stage 2 ECU+TCU. APR Intercooler. APR Ignition Coils. AWE AirGate Carbon Intake. Red Star Downpipe HJS 200cpsi. VPS Pre Muffler/Front Resonator Delete. ECS Big Bore Cast Aluminum Turbo Inlet Pipe and Silicon Turbo Inlet Hose. Pedal Commander Throttle Control System. 034 Motorsport Lowering Springs, Front Strut Brace & Transmission Mount.
    Nov 11 2020
    Lake Tahoe, CA
    OK, so it sounds like it might not be a good idea but I’m still at a loss as to how it’s detrimental. I’m getting turbo flutter when I let off the throttle at higher rom’s and I’ve also read that isn’t good for the turbo. Just looking for a fix to alleviate the flutter
    Jan 26 2019
    I still have my forge diverter on the car. With stage 2 tune. I haven’t had any issues whatsoever. But I do know that some have had issues. Not sure what’s the cause though!
    Nov 11 2020
    Lake Tahoe, CA
    Quote Originally Posted by Esmin23 View Post
    I read the thread regarding the increased IAT’s but that seems to have been remedied with the updated vacuum solenoid that Forge is including now. Still not sure what “problems” people have had with them? I ran the Forge on my old Jetta MKIV and had zero issues but I know the 3.0T is a different beast.
    Senior Member Four Rings
    Apr 26 2019
    United Kingdom
    The forge has failed on many cars. I've had two failures, both old and new design.
    The weistec has caused CELs on many cars.
    The ECS has caused CELs on many cars.
    If you are stock turbo then there is a good chance you'll get away with the weistec or ECS spacer. You may have luck with the forge but there is a good chance it will fail. I have not got enough hands to count the amount of failures I know of.
    If you are hybrid turbo then it is imperative you remain stock recirc valve otherwise you will run into CELs and drivetrain malfunctions. They are not designed for high boost, they aren't even designed for performance. They're designed to make a flutter noise, aka the noise your turbo will make when it stalls.
    The stock recirc valve has held above 3 bar of boost without fail. For comparison, stock cars usually target 1.2 - 1.3 bar of boost. There is no reason to "upgrade", they are only downgrades. Unless you like the noise.
    Jan 03 2019
    '19 Subaru Ascent
    NC
    Quote Originally Posted by Kondax View Post
    Could you elaborate more on this turbo fluttering concept please? Ever since I've gutted my air box I've had this super weird flutter intake noise, along with amazing swishing sound lol, wondering if that's what I'm hearing.
    It's just as I start to let off after heavy acceleration
    Nov 11 2020
    Lake Tahoe, CA
    The flutter I’m having sounds like a high pitched pulsing whistle. If you YouTube search “turbo flutter sound” all kinds of videos come up of the sound I’m hearing. I’ve read that it puts extra stress on the compression fan and can prematurely wear the turbo bearings which is why I’m searching for a fix. I would say unless you’re tuned and raising boost levels, the sound you’re hearing isn’t true turbo flutter but rather a byproduct of altering the intake box.
    Jan 03 2019
    '19 Subaru Ascent
    NC
    Ha, you know I'm tuned, but I've never heard it before messing with the airbox... I plan on getting a GoPro one of these days and recording it
    Nov 11 2020
    Lake Tahoe, CA
    I’m going direct with 034 tomorrow regarding it. If they say it’s fine, then I’m all good.
    Apr 26 2019
    United Kingdom
    Yes, it wouldn't be something I'd worry about. You can look into turbo flutter / compressor stall to find more info. It's the reason BOVs exist
    Jul 25 2021
    South
    Just wanted to add, I've had my Forge dump valve on for a few weeks now and no issues or hiccups to report. 18 SQ5 with EPL Stg 1 93
    Veteran Member Three Rings DreamTFK's Avatar
    Nov 01 2019
    Florida
    I have the one installed from ECS and have never had issues with it. Noticeable sound difference. Carried it over from my 19 to B9.5 without issue.
    2020 S4 P+ Quantum Gray BO
    ▪Wagner Competition FMIC w/Charge Pipes
    ▪ECS Carbon ECU Cover | ECS Diverter Valve
    ▪034 Trans Mount | Rear Sway Bar | Springs | 10/12mm Spacers
    ▪034 ECU/TCU Stage 2 93
    ▪Carbnlab Inlet + Airbox Mod/K&N 4" Filter
    ▪CTS Turbo Test Pipe
    Nov 11 2020
    Lake Tahoe, CA
    Gents, been working with Brett over at Go Fast Bits in Australia. They are currently working a complete redesign of the diverter valve for the EA839 motor. Loose estimate on completion is this fall/winter. I’m still getting flutter during hard acceleration with quick lift off. Hoping the GFB valve will correct it. I’ll update this thread as I get info.
    Apr 21 2023
    Frisco, Tx
    Flame away for bumping an ancient thread but at least my search skills run deep...
    So the post above talks about the GFB valve. I emailed GFB a bit ago and maybe I'll get a response maybe not. Maybe this is already exhausted somewhere else I didn't read.
    The stock OEM part number for the valve on my SQ5 is 06M145710F. One certain Audi parts sites it says this part fits a slew of engines including the 3.0 as well as 2.0 4cyl. So if our stock valve can work on a 2.0 possibly the guts of the valves are the same and the GFB mod would would in our valve even though GFB doesn't list it that way. I'm thinking of buying one and seeing if it will work but have to make sure it is returnable. Anyone ever opened our diverter or tried modifying it with the GFB parts?
    Nov 14 2022
    New England
    I just purchased an S4 and have the GFB diverter valve on my A4, and it was noticeable in reducing perceived "turbo flutter," in my opinion, and seemed to actuate better than the stock part. Maybe I can test it out on the S4 at some point - but would be nice to get GFB's take on it first.
    Apr 07 2011
    Home of the mighty beaver
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    Quote Originally Posted by S4James View Post
    I would check the pistons on the GFB as they dry up rather quick.
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Veteran Member Four Rings FromS60toB61.8t's Avatar
    Aug 26 2007
    07 Fahrenheit GTi, 09 S8, 17 GSW S 4-Motion, 19 S4 Black Optics
    If you're getting turbo flutter under high acceleration / high boost, there is another underlying issue. The only time your turbo should flutter is if you rapidly tap the accelerator just before it gets into boost now allowing for the DV to open up.
    What most are probably hearing is just the intake sounds of a little bit of air being pushed back.
    The only time you ever actually need a BOV is when running excess boost on a large turbo (which nobody is doing on stock turbo or TTE). Any other time a recirc valve / closed system is much more beneficial, especially on Audis which are designed to use that recirculated air. It's not as detrimental on the newer cars with the DV in the turbine housing as they have blow-through MAFs rather than the in-line intake MAFs, but there are no real benefits to it other than sounding JDM AF.
    Also contrary to what some say on the interwebs, the flutter doesn't actually do much to the turbo. In my 15 years I've had 2 cars with excess flutter and they were a B6 A4 with 110k on the clock with the factory turbo and a 2.7 allroad with with 150k on the clock with both factory turbos still.
    19' Glacier S4 Black Optics
    Junior Member One Ring
    May 30 2023
    2018 S4, 2008 Ford Mustang Shelby GT500 Cobra
    Philadelphia/PA/USA
    I updated mine to the newest version, stock audi. The .F version. But still getting it. I just want to make sure I'm not losing power from it. If there's something better or needed I'm all ears.
    Sep 12 2021
    North Houston Texas
    Me on the dyno, Stage 2 EPL, I was told this is normal flutter. Still wouldn't mind getting rid of it and getting louder blow off sounds
    https://youtube.com/shorts/MRZWFxviZ...tFmh90H5O2Hx6S
    May 30 2023
    Philadelphia/PA/USA
    Im stock turbo, once i check the code ill post it. odd how once i restart there no code.
    Jan 11 2020
    Ontario
    Bumping an old thread.
    This works ->
    https://www.turbosmart.com/product/b...umb-back-vr18/
    Bought this mainly because I've now had two failed OEM DVs. No other after-market has worked for me with an OTS tune (EPL / IE). This one functions as expected. My car is already loud AF so difficult to tell if it has any increased sound effects. It doesn't at low speed.
    2018 Audi S4 Prestige - Daytona Grey
    Logic Street Performance custom tune via Deadbeef Flash platform | Andy's Big Ass CF Intake | 034 J Hook Rotors | iSweep 2000 pads | Valved Exhaust Titanium straight pipe | CAP Decat 2.0 revision | CTS Turbo Intercooler | APR DTR8868 Turbo + RS Injectors + HiFlow HPFP + LPFP | Osman BicepBrah Ali PCV fix | OEM 4-bar MAP sensors
    Veteran Member Three Rings sandman00's Avatar
    Jan 02 2015
    queens
    Quote Originally Posted by TunedB9S4 View Post
    This works ->
    This is a great DV, better than stock. I have been using this one for a while now, first with the stock Turbo and then With the TTE710 and With the TTE810. No codes, better than stock, very reliable and sounds great too.
    Dec 29 2020
    Highland Village, Texas
    Quote Originally Posted by sandman00 View Post
    Other than potential failure, what do you mean by better than stock?
    Senior Member Two Rings brandonbanana's Avatar
    Jul 14 2018
    2010 Lexus IS 250, 2023 Audi Q8, 2016 Audi S7
    Oahu, Hawaii
    I had the diverter valve spacer and I can admit that it sounded gangster till I was leaking boost from that spacer lol
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    switching an audi from recirc to atmospheric dump is a level of heresy only second to mounting a set of te37’s or rpf1’s.
    +1 on the turbosmart
    Sent from my District Green iPhone 13 Pro using Audizine Forum
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Apr 07 2011
    lol. i ran rpf1s on my b5. I got no end of flak from one particular local purist. They were fantastic looking wheels.
    Established Member Two Rings Mr. Lin's Avatar
    Jul 17 2021
    2020 Audi S4
    Arizona
    Quote Originally Posted by Gunnarrrrr View Post
    *goes to return set of Enkei sneakily
    Mar 25 2015
    Placer County
    Quote Originally Posted by Mr. Lin View Post
    caught in 4k
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    May 22 2023
    MD
    the turbosystems valve seems like a good upgrade, might do that
    Apr 07 2011
    Bump, just installed a GFB T9380 and sure enough my throttle tip-in whistle noise SEEMS to have been mostly fixed. If I had to guess the stock light plastic piston was either not sealing to the machined surface, or simply putting out that high frequency resonance noise as air passed through the chamber. In any case the characteristic of the sound has shifted to a deeper note, and not as pronounced. Obviously with a bit turbo, and a big semi open intake like the IE one, more noise is just part of the game. But I found that particular sound really unpleasant.
    I had the EXACT same issue with the stock plastic DVs on my old B5 when i went to K04s.. They made noise. They worked, but part throttle spin up with mild boost and the would hum, honk, make crappy sounds.. yuck. Heavy duty piston style DVs fixed it.
    Feb 04 2019
    Georgia
    I used a GFB DV+ on my old MK5 GTI and it worked really well, never had a problem, held boost, and made throttle feel better. Are you experiencing these same benefits going to this GFB DV replacement for OEM?
    GFB DV is backed by a lifetime warranty. So I'm wondering if I should go this route or the TurboSmart DV mentioned above. Mostly going for performance, but if they both work well, then I would only be chasing sound differences as they're priced very similarly.
    Apr 07 2011
    Well its a very subjective sort of thing isnt it.. I mean it might be better, but nothing night and day.
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    Used a GFB DV on my B8 2.0. Wound up pulling it off after a few thousand miles due to its apparent ineffectiveness. Went back to an OEM Revision "D" and it's been fine.
    Not sure I would spend my money on one for my S4.
    Apr 07 2011
    I had a gfb hybrid adjustable valve for my 1.8t, it was a work of art, but it absolutely did not work on that car at all. The gfb valve i got is a simple DV, no hybrid nonsense. I cant imagine it not working.
