I see that there is a "wheel change" soft switch in the MMI. What does it do?
I understand that you need to set this to on when you change a wheel, but what does it do? Does it discharge the air or increase the air in the suspension? And for what purpose?
So, I have two floor jacks that I use to rotate tires front and back. Typically, with all my other cars, I just jack up the front and back together on one side, then swap the wheels/tires. If I wanted to do that for the SQ7, do I need to set this "wheel change" mode first? (Thus I need to understand what this does.)
I looked it up in the manual, it didn't say much... It didn't even say that I needed to turn it off after changing a wheel.
