Results 1 to 24 of 24
    Jun 20 2021
    Dipstick for 3.0t engine
    Hi,
    There is a dipstick to 3.0t engine? I didn’t found one
    Thank you
    Dec 30 2018
    Philadelphia
    Quote Originally Posted by hananmori12 View Post
    Hi,
    Thank you
    https://www.fcpeuro.com/products/aud...ick-06e115611h
    Looks like ECS does not have the factory version right now but they are available.
    Edit: I apologize, did not realize that you were asking if there was one from the factory. The 3.0T did not come with a dipstick when new but has a plug in the tube where the dipstick would go. I believe the poster below linked a video of where the tube is located. It's located on the right front side of the motor.
    Established Member Two Rings visceralsoup's Avatar
    Mar 11 2018
    2000 Santorin S4, 2001 Casa S4, 2003 Mazda Miata
    Virginia Beach
    https://youtu.be/ImSA9qGPtRQ
    Sent from my GM1910 using Tapatalk
    Jun 20 2021
    Quote Originally Posted by visceralsoup View Post
    Its look like he use 06E115611H dipstick for 2.0 engine.. I will order it
    Jun 20 2021
    Ok i saw ending with E its 2.0 and H its 3.0.
    Thank you guys!
    Veteran Member Three Rings Clun9's Avatar
    Oct 09 2008
    B8.5 S4, SQ5 & Unicorn 337
    What’s stupid is that our motors have a slot for the dipstick to begin with (3.0T). Def needed to buy and have as you can’t rely on the mmi for accuracy.
    MK4 337 GTi (custom widebody) | Bagged B6 S4 (SOLD BUT NOT FORGOTTEN) | B8.5 S4 (STOLEN & TOTALED) | Dual Pulley B8.5 SQ5
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Thank you guys!
    Correct. Order the one with the H at the end. That's the correct one for the 3.0T.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Junior Member Two Rings
    Apr 15 2021
    Durty South
    Just a heads up there have been a few reports of the little plastic endpiece breaking off on the aftermarket versions of the dipstick, although the OEM ones are apparently fine. I bought an OEM one and just keep it in the storage tray next to my spare tire out of paranoia.
    Incidentally I have no idea why the engineers at Audi designed a dipstick with a piece that can break off instead of just going with a regular metal stick.
    2014 SQ5 P+ Phantom Black
    2019 VW Golf R (sold)
    2016 SQ5 P+ Sepang Blue (totaled by a stop sign runner)
    2015 Golf TDI (Dieselgate buyback)
    2014 Q5 2.0T P+ (sold)
    2013 VW GTI (sold)
    Jul 31 2016
    PA
    Quote Originally Posted by squatch5 View Post
    Because Audi considers it a tool, not meant for permanent install. Most of the Audi ones don't break anyway, its usually the aftermarket brands that do and the Audi ones are fine.
    Or just buy an all metal one. Burns your hand, but it won't break lol.
    Sent from my SM-G988U using Audizine Forum mobile app
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Mar 07 2020
    Minnesota
    Because sometimes it's easier to read the oil level on a plastic tip than a metal one. That's my guess. And it fits with my experience of German engineering ... solve one problem, create two more.
    Unlink my BMW, at least my SQ5 has provisions for a dipstick ... in the BMW the service manual for measuring oil not using the oil level sensor is to drain the oil and measure how much came out. If between oil changes pour it back in...
    On my first Audi (1998 A4 1.8T) I went to check my oil, pulled up the dipstick, and the tube broke off the engine. That was just one of many failures on that car.
    Senior Member Two Rings jeromium's Avatar
    Apr 19 2020
    2014 Subaru Crosstrek
    I was about to order a genuine Audi one from ECS but damn, $18 shipping on a lightweight $30 product.
    Edit: Wound up ordering it from audi.OEMpartsonline.com, $38.18 after shipping.
    2017 Q5 3.0T (Moonlight Blue/Black Optic/Chestnut Brown) BBS CI-R Satin Bronze | KW Street Comfort
    2014 Subaru XV Crosstrek Limited (Desert Khaki/Black)
    IG @moonlightbub_q5
    Apr 19 2020
    Too funny, had to share this response I got from Audi.oempartsonline.com after ordering dipstick part #06E-115-611-H.
    Subject: CAR DOESN'T HAVE A DIPSTICK
    Your vehicle doesn't have a dipstick, only a plug that looks like one.
    The part number for that one is 06e115418. I will cancel this order. Please reorder under this part number if you still want the part.
    IG @moonlightbub_q5
    Feb 14 2017
    Gulfport, MS
    Quote Originally Posted by jeromium View Post
    Crazy. So, what name do those Bozos give to part #06E-115-611-H? Maybe "oil extraction tube insert device" or something else stupid like that?
    Audi calls it a dipstick:
    Jul 31 2016
    PA
    Just order from FCP.
    Apr 19 2020
    Quote Originally Posted by MSq5 View Post
    They just call it a dipstick too.
    Quote Originally Posted by djn876 View Post
    Yup, that's what I did yesterday immediately after getting that dumb email. And somehow the price had gone down to $10.89 from about $30 when I checked the day before! I had to quadruple-check I was ordering the genuine one.
    IG @moonlightbub_q5
    Jul 31 2016
    PA
    Lol, maybe it all worked out OK then. And yeah I checked twice as well because I figured for sure that wasn't the Audi brand price.
    Veteran Member Four Rings spijun's Avatar
    Oct 10 2010
    Audi Q5 2.0TFSI S tronic
    Sarajevo, BiH
    Oil Dipstick
    1.8/2.0 TFSI: 06J 115 611 E
    2.0 TDI: 03L 115 611 E
    2.7/3.0 TDI: 059 115 611 AB
    3.2 FSI /3.0TFSI: 06E 115 611 H
    S5 4.2: 079 115 611 AB
    OR
    OEM T40178 for Audi Oil Gauge & Oil Dipstick
    Senior Member Three Rings Raistlin's Avatar
    Apr 27 2005
    New Jersey
    I ordered the OEM one from Europaparts, they said the dipstick is not meant to stay in the engine. Is everyone just using when checking oil or leaving it in?
    B9 SQ5 Quantum w/ Magma Nappa, S Sport, Cold Weather, Driver Assistance, Carbon Atlas
    Previous:
    2014 Q5 P+ 3.0T - Scuba Blue - Black Sport Interior
    Nav+ - S Line+ - Side Assist - Bang & Olufson
    EPL Stage 1 & TCU Tunes
    Jun 20 2021
    Quote Originally Posted by Raistlin View Post
    I didn’t know if that can stay so I use it and put it next to the spare wheel after that
    Feb 14 2017
    Gulfport, MS
    Leave it in.
    Junior Member Two Rings WhatnxtQ5's Avatar
    Feb 04 2021
    Lk Steven, WA
    Ordered the OEM T40178 Oil Dipstick for my 3.0 TDI. Called the Dealership and they said that they could calibrate it, no problem. Said that they have done a few for customers.
    Apr 19 2020
    Quote Originally Posted by WhatnxtQ5 View Post
    Good to know, I'll have my dipstick before my next scheduled service in October.
    IG @moonlightbub_q5
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Leave it in.
    +1. Real men don't pull out
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Feb 04 2021
    Lk Steven, WA
    Got this one on Amazon: https://www.amazon.com/dp/B07R7QY3ZH...roduct_details
    Went to the dealer and had it calibrated for my 3.0 TDI. Top adjuster ring was set at 93. Oil measurement should be between 12-14 on the oil level display. Looks just like the one that the dealer uses.
