Results 1 to 4 of 4
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    How to fix: DTC 01826 and 00778
    I have those two DTC pop up with a VCDS scan
    01826 Sensor for Steering Angle G85 Supply Voltage
    35-00
    00778 Steering angle Sensor G85
    37-00 - Faulty
    My traction control light is on maybe every 2 out of 3 times I drive the car
    I tried to do an adaptation with vcds but it didn't take.
    When I look at the measuring block for steering angle and turn the wheel, it doesn't move off of 0 degrees.
    I assume my sensor is fubar and it just needs to be replaced?
    Does anyone have a PN/link to this part? Anyone ever replaced this before?
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Veteran Member Three Rings Atomic Avant's Avatar
    Jul 11 2016
    2005 S4 Avant, 2016 Q5
    Ontario, Canada
    Part number: 4E0953541B or 8E0953541E depends on VIN split. Dealer could tell you which it is.
    That part number is for the clock spring as the steering wheel sensor is part of it.
    Mar 31 2014
    KY
    Quote Originally Posted by FlyingNipples View Post
    Damn that little thing is expensive. oof. Thanks for the P/Ns
    My vin is 5AXXXXXX so I think I need 4E0953541B
    Jul 11 2016
    Ontario, Canada
    Quote Originally Posted by badger. View Post
    Yeah, I would look for something used first just in case.
    Sent from my GM1917 using Audizine Forum mobile app
    AKA: FlyingNipples
