    Senior Member Two Rings krewbrew's Avatar
    Apr 26 2014
    2013 Touareg V6
    Westchester County NY
    2015 A7 parking aid control module location
    Can anyone tell me where this is located? I'm trying to disable the parking sensors while keeping the rear camera function.
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    On the A6 it is right side of trunk above the fusebox/relays. I'd assume the A7 it is in a similar location.
    FWIW disconnecting them might throw other codes that could affect other systems.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Apr 26 2014
    2013 Touareg V6
    Thanks. Turns out it is behind the trunk fuse box in the A7. Removing it entirely does not generate error codes but eliminates the rear camera function in reverse as well. Removing just the center of the three connectors disables the front parking sensors, which are the ones that bother me the most from their excessive beeping. It does generate codes but no visible lights on the dash, but also creates one beep every time you put the car in reverse for the first time after staring it. Trying to figure out a way to code that out using obdeleven.
    Established Member Two Rings Sima-Koya's Avatar
    Jun 15 2020
    Serbia,Belgrade
    You need to load dataset via ODIS to disable fronts,so dont waste time with OBD11,it cant do it.
    Contact:
    Whatsapp : wa.me/381653086899
    Telegram : https://t.me/simaservis1108
    Phone Number : +381653086899
    MHI2 / MIB2 / MMI 4G
    Maps update / firmware update / Android Auto / Carplay
    Apr 26 2014
    2013 Touareg V6
    Thanks. Any way to disable all parking sensors, not just front, but keep camera functionality on reverse?
