I threw a low dollar bid out on a Copart listing last week totally not expecting that I'd win it... but I did. Copart fees along with having to rent a Uhaul to bring it home basically doubled the price that I paid for it, but I'm pretty excited about it. I've been eyeballing MK1 TT's for almost a year now.
This TT is in really good shape, while simultaneously being in terrible shape. Carfax shows it was a New England car until around 2012 (I haven't found any rust yet (fingers crossed), when someone in Oklahoma bought it. I'm 98% sure that the majority of its time in OK was just spent sitting and baking in the sun. Tires are all date coded for the end of 2011. The clear coat is decimated. Headliner and driver's door card glue have given up on life - the headliner is annoying, but the door card is problematic as it catches on the window when it is being rolled up, and the glue is smearing off onto everything. All the vacuum/rubber hoses under the hood are crusty and cracked too.
The auction listing said that it started and idled when it arrived (I'm having some doubts on this), but I think it sat for so long with a dead battery that it forgot the key, so I can't start it because the immobilizer is active. I have a VCDS and the cluster shows that zero keys are currently programed. Everything that I've read tells me that obtaining the SKC will be tricky, but that I can get a $25 cable off of Amazon to pull the Hex code from the cluster - security code will be in there. I'm still researching this. In my multiple scans with VCDS, I did check the Service Interval. Only 240 miles since the last service.... but that was 1265-ish days ago (3.5 years). I can't hear the fuel pump prime when I key on... so that's problematic, as well. My impression of immobilizer problems was that the car would start, but turn off after one second. Luckily, I do have an AEM High Flow pump that I just pulled out of one of my other cars - so if need be, I have a pump available.
The car is about 95% stock though. It still has all of the underhood plastic covers (Coolant/PS cover, Engine Cover, and Battery Cover), although the little screws are all missing. Konig wheels with keyed lug nuts/bolts (and I can't find the key), a Farenheit head unit that sticks out a couple inches, and a brand new looking aftermarket power steering cooler mounted in front of the radiator/condenser. I'm excited to get started screwing around with it though. Most pictures and info to come.
