Results 1 to 26 of 26
    Established Member Two Rings Eastcoastmod's Avatar
    Dec 09 2019
    04 B6 S4 Sedan 4.2 manual. 05 B6 S4 CABRIO TIP
    Nova Scotia Canada
    Starter relay location or part number please
    Hi all
    Starter no longer engaging after going through a deep puddle.
    Car car be push started and runs fine all day long.
    I've searched in vain for the location and part numbers so I could pull and check the relay.
    I gave up and called my Audi dealer.
    Even they had no clue which one it was despite using my VIN.
    Does anyone know which relay under the dash is the correct one?
    Or what the correct part number is.
    I'm fairly certain my starter is toast but want to be sure before I order one.
    Thanks in advance.
    Colin
    my first Audi 05 B6 S4 4.2 TripTronic Cabio less than 55000 miles
    Veteran Member Three Rings Atomic Avant's Avatar
    Jul 11 2016
    2005 S4 Avant, 2016 Q5
    Ontario, Canada
    Quote Originally Posted by Eastcoastmod View Post
    Hi all
    Thanks in advance.
    Colin
    Its one the of relays under the ECU under the rain tray.
    4 - Locking relay for starter (J434)
    Veteran Member Four Rings MugelloB7RS4's Avatar
    Feb 06 2015
    Quote Originally Posted by FlyingNipples View Post
    I think that switch is the Clutch pedal switch, but is referred to as "Locking Relay for Starter"
    However there are two separate relays for the starter behind the drivers knee bolster. Those should be the main Starter relays.
    Jul 11 2016
    Ontario, Canada
    Ah right, What I said is for the clutch switch interlock. Not the actual relay.
    Can water even get to those relays?
    Feb 06 2015
    The ones by the drivers knee, probably not, but the ones in the plenum yea for sure. So it's possible that it's the clutch switch that's underwater. That would still stop the car from starting if the ECU doesn't see the clutch pedal depressed.
    I can't speak for the B6 S4's, but I know the B7 RS4's are known for starter motor issues. I just replaced mine last week. Common issue for sure, but not sure if that extends to the S4 or not. Either way, its a good idea to check all these relays first as they are easier/cheaper to address.
    Dec 09 2019
    Nova Scotia Canada
    Thanks guys
    Interesting.
    I had absolutely no issues with the starter before the massive downpour.
    I just checked and the depress clutch message is not disappearing when I push the clutch in.
    I don't remember if it ever did though.
    Sadly I will have to work on it in the rain to get at it.
    Feb 06 2015
    Thanks guys
    Interesting.
    Im pretty sure mine was the same way. The depress clutch message was always there. I found mine was worse when it was damp or cold. It would be brutal to try and start. From what I've read its the starter solenoid circuit that wears and it becomes harder and harder to engage especially if it's cold/wet. Mine would cause an intermittent no crank. Once it was warm it seemed fine for the day, but if it sat for too long it could be a pain. New starter made a world of difference.
    Good luck.
    Dec 09 2019
    Nova Scotia Canada
    The dealer gave me part number 4H09521253A for relay number 4.
    I just happens to be in stock.
    Before I go pick it up, I have one question.
    According to the diagram above, relay 4 looks to have two functions.
    It looks like it's a starter relay and a break booster relay.
    Am I reading that correctly?
    If so, and my brakes work fine, would that mean the relay is fine as well?
    Thanks again
    Colin
    Feb 06 2015
    Thanks again
    Colin
    The footnote next to the relays read like this
    -J53 Starter Relay - For Engine code AUK, BKH and BNS Only
    -J569 Brake Booster Relay - Not applicable for engine code AUK and BKH through 2005 model year.
    I'm pretty sure the engine code for your V8 is BBK, so I'm not too sure to be honest. I'm pretty sure the way the relay box is set up is you either have one or the other. I don't think the relay would control both the starter and the brake booster. That's the way I read it anyway.
    Dec 09 2019
    Nova Scotia Canada
    Thanks again all.
    I fully expect it to be the starter but I picked up the starter interrupt relay just in case.
    Heading out now to throw it in.
    I hope to find some water under that rain tray.
    If not, the new starter goes in Thursday.
    Not looking forward to that though.
    Jul 11 2016
    Ontario, Canada
    Thanks again all.
    If you don't see it under the rain tray it doesn't necessarily mean your ECU box is dry.
    Good luck and I look forward to hearing the result.
    Dec 09 2019
    Nova Scotia Canada
    Ugh!
    Took the inside apart, pulled the relays, opened the new bag and notice the relay pins were a touch smaller.
    Investigated.
    They sold me 30 amp relay.
    Fortunately I didn't plug it in and try to start it.
    The correct part number has no A at the end and is 50 or 70 amps depending on who makes it.
    Another work day lost. :(
    Jul 11 2016
    Ontario, Canada
    Ugh!
    Investigated.
    Any local junk yards? If you have a U pull near by I would go there. hand full of relays for a few bucks
    Dec 09 2019
    Nova Scotia Canada
    Our yards here don't have much.
    We don't really have the population to generate decent yards.
    Most stuff gets brought in from Ontario when you call the yards to order something.
    The rain stopped finally.
    I tried the the starter relay and no surprise that it wasn't the issue.
    Headed out to remove the clutch pedal interrupter switch/relay under the tray.
    The dealer was useless in looking up the part number for that relay as well.
    Jul 11 2016
    Ontario, Canada
    If the clutch switch, relay is bad and you don't have a relay handy, A short bit of wire and 2 blade connectors to jump the connection. (basically what I have since I am swapped from Auto to Manual)
    Jul 11 2016
    Ontario, Canada
    Here is what mine looks like to give you an idea.
    Attachment 244570
    Sent from my GM1917 using Audizine Forum mobile app
    Dec 09 2019
    Nova Scotia Canada
    Pulled it. Not sure how to check it. I like the jumper mod anyway. :) Sadly I'm
    out of spades.
    Jun 09 2014
    BMW E28 with S54 Swap, rack and pinion conversion, vacuum brake conversion
    Jacksonville,FL Lincolnton,GA
    out of spades.
    Diamonds, Hearts, Clubs? Still should have 39 cards to play You can check the relay by putting a 12V signal across the magneto, listen for it to engage and then check continuity across the switch
    Jul 11 2016
    Ontario, Canada
    out of spades.
    Here is the part number of a spare relay. I am to far from you to help but here is the OEM and an aftermarket part number.
    As for testing it. If you can put power across pins 1 and 2 (the opposite little guys) you should hear/feel the relay actuate.
    Dec 09 2019
    Nova Scotia Canada
    Sadly I just tried the jumper mod and still no crank. Looks like it's the starter.
    Dec 09 2019
    Nova Scotia Canada
    It's interesting that the depress clutch to start message is there despite the jumper mod.
    Jul 11 2016
    Ontario, Canada
    Mine was always there with a relay or jumper. didn't matter. I am not even sure if the message goes away or not.
    Feb 06 2015
    Mine is the same, I think it's always there.
    Dec 09 2019
    Nova Scotia Canada
    Well it was the starter. Although the starter gave me no signs it was about to go, what a difference in cranking speed with the new one.
    Jul 11 2016
    Ontario, Canada
    Glad you got it fixed!
    AKA: FlyingNipples
    Dec 09 2019
    Nova Scotia Canada
    Was a pain in the ass but it's fixed. Parking on hills to get by was irritating.
