Results 1 to 31 of 31
    Sep 28 2009
    suburb
    Transmission class action settlement!!
    https://considertheconsumer.com/clas...EDU54AXveJ25RA
    The following Audi car models are believed to be included in the settlement proceedings:
    Audi S4 (2010-2015 models);
    Audi S5 (2010-2015 models);
    Audi S6 (2010-2015 models);
    Audi S7 (2010-2015 models); and
    Audi RS5 (2010-2015 models).
    Audi S7 stage 3 w/srm turbos
    Audi B8 S5 stage 3 w/apr supercharger
    Audi SQ7
    Audi Q5 3.0 EPL stage 2 single pulley (gone)
    Audi Allroad 2.7 stage 3 (gone)
    Audi B5 S4 stage 3 (regrettably gone)
    Audi B8 S5 (gone)
    Established Member Two Rings IssaWrapVinyl's Avatar
    Nov 24 2019
    10’ VW Jetta 2.0t Wolfsburg 09 VW CC 3.6 4Motion -Sold
    Quote Originally Posted by flyfishing View Post
    My S6 got a brand new transmission total was $17000. Do I get reimbursed, and do I contact Audi of America directly?
    Established Member Two Rings tuscani66's Avatar
    Aug 09 2018
    Pittsburgh-PA/Acworth-GA
    Thanks - got a 2016 S7 with transmission issues, so I hope they update the years part.
    2016 S7 Prestige in Mythos Black over Arras Interior.
    Other Garage Items : Volvo S60 R / Lexus RC F / Saleen S281-Cobra Conv / Porsche Cayenne Turbo S / Toyota Tundra
    Veteran Member Three Rings Burkeomatic's Avatar
    Feb 22 2021
    14 A8L 4.0T, 96 Corolla Wagon
    San Antonio
    Damn, I knew I should have got a S6.
    2014 A8L 4.0T - DS1 Stage 4/JHM TCU, FE Axlebreakers, E85
    Mar 25 2020
    Coconut Creek, FL
    Should I wait to ECU/TCU tune to see how this settles? 2013 S6. I have the obvious clunky shifting. 67k miles 3rd owner. I've never had a warranty Would love to have the DSG rebuilt, if it would be covered. Thank you.
    Apr 08 2008
    Columbus, OH
    Quote Originally Posted by DGr1FF View Post
    I would just have a good indy VAG shop do it and bill/get reimbursed by audi.
    Sent from my SM-G998U using Audizine Forum mobile app
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by IssaWrapVinyl View Post
    Looks like the details of the settlement are not yet public. However, it will likely include reimbursement up to a capped amount for repairs already done, as well as extended warranty for everyone else. Wait for the settlement details to be published.
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Nov 24 2019
    They won’t rebuild it. You’ll get a new trans. Check the fluid if it’s ugly it’s the clutch pack. If the fluid is clear obvi check mounts first. Check faults if mounts are good. If u have shift valve/fork faults the car needs a mech. Regardless the extension will cover the transmission and any components.
    Nov 24 2019
    I have replaced a few mechs (Audi tech over here) the valves/forks that select gears stick. And cause a rough shift. A tune will possibly correct it until the mech has failed completely and need a new one. And since you’ve flashed the software it’ll definitely TD1 flag because we have to perform the warranty check in odis everytime powertrain/drivetrains needs fixing. And you don’t get a new trans out of it.
    Dec 19 2011
    When you say “you’ve flashed the software it’ll definitely TD1 flag” are you referring to a TCU tune? I don’t have that yet and I’m at 88k. But I do have an apt stage 1 tune.
    Nov 24 2019
    TD1 flag is any changes in code. Apr tune will definitely cancel your chances at a new trans. Even if u flash it back to stock. It still picks up that change in coding. We flag a bunch of cars not purposely. Most times we don’t even know the car is tuned or has been. But in order for Audi to approve warranty work on driveline or powertrain repairs, they want us to run the warranty check which checks the coding in lol the modules. They’ll back flag us the techs however many hours the repair paid and the dealer eats a $17k transmission or whatever the fix was. Unless you have a 2021 Audi with MTM un-detectable software lol your gonna get TD1 flagged.
    Sep 27 2008
    Phoenix
    In that case go to a 3rd party to get the work done. The class action covers work performed at locations other than an Audi dealership.
    Nov 24 2019
    Quote Originally Posted by wootwoot View Post
    No, this is if you had already got the work done elsewhere and can prove what you paid. Due to there being a warranty extension now. U have to bring it to the dealer. They will not reimburse you. After they have released the settlement statement.
    Veteran Member Four Rings fastboatster's Avatar
    Apr 23 2019
    2010 Audi A4 3.0T, lol
    CA
    I wonder how far this warranty extends, to what mileage and whether only the first owners are eligible. My car has 150+ kmiles, I’m probably not going to be eligible. But heck, even something would be good.
    I’m not at all surprised by this, putting inherently flawed designs out is so VW and Audi. I doubt you can create a mass market DCT for 50-60k cars and not cut any corners to cut the costs. Seems like Audi banked on their not so reliable but performing good for their respective classes ea888 gen 2 and DL501 to increase their market share in the early 2010s and then use the money generated from the projected sales of newer cars like b9s to deal with warranty and class action issues.
    Deactivated Three Rings KayS4's Avatar
    Mar 25 2012
    VW TDI
    Great North
    What happens if u did the work and sold the car? Hmm
    Oct 18 2016
    WA
    "Per press time, the Audi Defective Transmission Class Action Lawsuit Settlement Agreement’s details have not been released to the public."
    A quick search doesn't turn up a whole lot for this case, and while the parties involved may have reached an agreement, nothing indicates that it's a done deal and able to start paying out on claims. Which is to say,
    I have no idea how anyone in this thread is saying how the claims process will go when the documents that define the process aren't yet available.
    Long live the Rhombus
    Established Member Two Rings pointblank9957's Avatar
    Jul 12 2019
    2014 Audi Allroad Volcano Red, 1998 A6 Avant Casa, 1997 A6 Avant Emerald
    Sheboygan, WI
    Well it looks like I'll be hopping on this ASAP! 2016 S6 with 67k miles, trans completely locked up on the highway and left me stranded in Milwaukee. Waiting on the installation bill of my used transmission, so far the bill is at $4k for parts and used trans.
    https://www.audizine.com/forum/showt...rophic-Failure
    2014 A4 Allroad 1/49
    1997 A6 Avant 1/141
    1998 A6 Avant 1/10
    Kujispeed Products:
    Audi C4 Avant LED 3rd Brake Light
    Audi C4 Sedan LED 3rd Brake Light
    Delta CC Bluetooth audio streaming Integration
    Apr 08 2008
    Columbus, OH
    Quote Originally Posted by pointblank9957 View Post
    As of now, it's not through 2015 model year. Hopefully it gets bumped to the newer models as my 16 ages.
    Jul 12 2019
    Sheboygan, WI
    Quote Originally Posted by japanada View Post
    so I saw, still doesn't hurt to see if they'll honor it since my car has all the same symptoms they describe.
    1997 A6 Avant 1/141
    1998 A6 Avant 1/10
    Kujispeed Products:
    Sep 28 2009
    suburb
    i bet we will all receive letters in the mail in the next couple of months.
    so i guess it is time to launch my car more? :)
    Audi SQ7
    Audi B8 S5 (gone)
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    Premature launching
    18 S6
    Dec 19 2011
    I just have jerks at times when driving. Some slipping also but I chalked that up to having a stage 1 apr tune. I’m goi g to get the tcu tune in the next few weeks. Hopefully that will fix it. Should I get a tranny flush?
    Aug 14 2019
    Tampa
    You could try running a clutch calibration with vcds also
    18 S6
    Dec 19 2011
    Don’t have Vcds but I do have OBDeleven. How do I run the calibration with that?
    Aug 14 2019
    Tampa
    Quote Originally Posted by rlny View Post
    I'm not aware of that being possible via obd11
    18 S6
    Senior Member Three Rings robocop47's Avatar
    Oct 21 2019
    Cincinnati, OH
    Quote Originally Posted by Audisthesia View Post
    It’s possible, just an absolute pita to accomplish.
    Aug 14 2019
    Tampa
    Quote Originally Posted by robocop47 View Post
    Yeah so I'll stick with 2 mouse clicks in vcds to do it
    18 S6
    Sep 30 2014
    NorCal
    Someone running that class action settlement needs to get their data correct because the S7 didn't exist before the 2012 model year, and didn't debut in the US (where the suit was filed) until the 2013 model year.
    Current vehicles:
    2009 A4 Avant Premium Plus - Aruba Blue Pearl
    2016 S7 Prestige - Sepang Blue Pearl Effect
    2023 Q5 Sportback Premium Plus - Chronos Gray Metallic
    Past vehicles:
    2001 A6 - Santorin Blue Pearl
    2003 A4 - Light Silver Metallic
    2015 Q3 - Monsoon Gray Metallic
    2018 S5 Cabriolet Prestige - Glacier White Metallic
    Oct 21 2019
    Cincinnati, OH
    Quote Originally Posted by HowYouDoin View Post
    The C6 S6 also didn’t have a DSG either now that you mention it
    Junior Member One Ring
    Aug 07 2021
    MN
    Curious if the facelift cars have some update that makes them not cover those?
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Apparently the lawsuit has gone through several amendments. I don't have access to the text of the lawsuit or the settlement. OP's quote seems to be from a reporter's article, not a lawsuit filing. From another article:
    "According to the Audi defect class action lawsuit, VW manufactured and sold 2010-2014 model year Audi S4, S5, S6, S7 and RS5 vehicles with defective direct-shift gearbox transmissions that caused “sudden, rough, unexpected shaking and violent jerking” when drivers attempted to accelerate and shift the cars into second, third or fourth gear and attempted to decelerate. A later amended claim added 2015 models to the lawsuit."
    I would interpret that as the first gearbox was sold in 2010 in at least one of those models, and by 2014 (amended to 2015) had been sold in at least one year in all of those models. This article further states:
    "“The proposed Settlement provides for a percentage reimbursement to all Settlement Class Members that have paid out-of-pocket expenses for one Covered Repair (of a diagnosed condition of transmission shuddering, juddering, rough shifting or improperly entering into “limp mode”),” the document says. VW will also pay back vehicle owners a portion of their transmission repair or replacement costs based on the mileage and age of the vehicle when the repair happened. Reimbursement ranges from 100 percent for vehicles that were up to four years old and under 50,000 miles, to 20 percent for vehicles that were between eight and nine years and between 80,001 and 90,000 miles. For those who had their repairs done at a non-authorized Audi dealer, reimbursement for replacement of the mechatronic unit is capped at $5,000 and replacement of the transmission is capped at $12,000."
    As bahula03 implied in post #16, wait for the settlement document to be published.
