Results 1 to 25 of 25
    Veteran Member Three Rings AudiC7Owners's Avatar
    Jan 14 2016
    Wilmington, NC
    DIY Video(s): How to change your 3.0T Brake Rotors & Pads
    Here's my DIY Videos on replacing your Front & Rear brake rotors/brake pads. I used the Zimmerman rotors/Akebono pads kit from FCP Euro (they aren't a sponsor), and the kit came with rotors, pads, brake grease, and rear brake metal guides. It does not come with new hardware, so if you want to replace any of that you will have to purchase it separately.
    The job is pretty easy, but messy. You will need VCDS or OBD11 to complete the rear brakes.
    *****This is for the larger brake rotors that come on the 3.0T vehicles. There are videos on youtube about changing the brake pads/rotors for the smaller diameter rotors already*****
    Tool List:
    Front Brakes:
    -Blue Loctite
    -Brake Grease
    -Flathead
    -9mm Hex Bit (Must be small enough to fit into the caliper... I got mine from O'Reilly auto parts locally)
    -T30 & T45 Torx Bits
    -Socket Wrenches
    -22mm Socket
    -Something to hang the caliper with/secure it so it doesn't stress the brake line
    -Breaker Bar
    -Torque Wrench
    -Hammer/Mallet
    -Caliper Piston Compressor
    Rear Brakes:
    -Blue Loctite
    -Brake Grease
    -T30 Torx
    -Needle Nose Pliers (or thin 15mm Wrench)
    -Socket Wrench
    -13mm Socket
    -Hammer/Mallet
    -VCDS or OBD11
    Torque Specs
    Front Brakes:
    Brake Caliper to Brake Carrier Bolts: 30 NM
    Brake Carrier to Wheel Bearing Housing Bolts: 196 NM
    Front Cover Plate Bolt: 10 NM
    Set Screw: 10 NM
    Rear Brakes:
    Brake Caliper to Brake Carrier Bolts: 35 NM
    Set Screw: 10 NM
    Noteworthy Information:
    -There is allegedly a way to disengage the Electronic Parking Brake without VCDS/OBD11, but I haven't found the DIY yet. If you know it, let me know so I can add it.
    -The rears are way easier to do than the front, but neither are very hard.
    -You don't have to remove the carrier for the rear rotors. Just be careful putting in the new rotor and don't scratch it.
    -After you have everything installed and your brake fluid reservoir screwed back on, pump your brake pedal until you feel pressure build back up in the pedal before driving.
    -When bedding in the brakes, do not come to a complete stop. Bring it down to about 5mph, then start again. Do not let ABS engage.
    Kwikstix DIY Video Thread
    //2013 A6 Prestige 3.0T |IE Stage 2 Single Pulley | Berk TCU Tune | Injen Intake | Cende Valvetronic Full Exhaust | Gutted OEM Catalytic Converters | Merc Racing HX | H&R Sport Springs | 034 Motorsports Control Arms & Engine Mounts | Eurocode Drivetrain Mount Inserts | Eurocode Front & Rear Sway Bars + End Links | P3 Multi Gauge | StoneCarbon2009 RS Style Grille //
    Veteran Member Four Rings 09S5's Avatar
    Dec 04 2015
    A8L, 4X4, c6 VETTE, New CTS-V
    TN
    Thanks.
    Sent from my SM-N976V using Tapatalk
    Mar 14 2019
    Miami, FL
    You can retract the e-brake motor by disconnecting the connector and manually applying 12v to the motor. You just need to pay attention to the polarity. One way it retracts and the other way it presses on the pad. After you are done with the change, re connect the connector, engage and then disengage the e-brake.
    Veteran Member Three Rings Burkeomatic's Avatar
    Feb 22 2021
    14 A8L 4.0T, 96 Corolla Wagon
    San Antonio
    I would add a note to be very careful with the front caliper pins and not to over torque them. I did, and I had to helicoil the carrier as it boogered the threads up so bad they were mostly gone.
    2014 A8L 4.0T - DS1 Stage 4/JHM TCU, FE Axlebreakers, E85
    Jan 14 2016
    Wilmington, NC
    Quote Originally Posted by Cayo71 View Post
    Good to know!
    - - - Updated - - -
    Quote Originally Posted by Burkeomatic View Post
    Damn dude... never heard of that happening before
    Feb 22 2021
    San Antonio
    Quote Originally Posted by AudiC7Owners View Post
    Good to know!
    - - - Updated - - -
    It was half over torqueing, half I may have put one in a little crooked. I have this innate ability to ruin odd parts, in the evening, on the weekend, when I need the car the next morning.
    Jan 14 2016
    Wilmington, NC
    Me and you both man. Story of my life.
    Senior Member Three Rings GodFatherMav03's Avatar
    Oct 15 2009
    2012 Audi A6 3.0T Prestige, 2013 Audi Q5 S-line 3.0T
    Gaithersburg/MD
    Bout to be attempting this soon.
    Jun 12 2019
    MK5 Rabbit 2.5 5spd
    Natick, MA
    Quote Originally Posted by GodFatherMav03 View Post
    Double check your toolbox for that 9mm Allen. Not a standard size, no Allen wrench kit will come with it. I had a hell of a time finding one locally (with the car in pieces of course lol), called about 10 local auto parts stores before I found one that had one on the shelf.
    2016 A6 P+ 3.0T / Aviator Blue Metallic / APR Stage II Single Pulley 93 Octane / BG_SQ5 tcu / MercRacing hx v3 / Hartmann Rotor Reps 20x9 ET40 w/ 265/35-20 PS4S / 0-60 3.56 sec
    Feb 22 2021
    San Antonio
    Quote Originally Posted by 2k16A6 View Post
    This x1000. I got the car apart, and had to steal the wife's car to go to O"Reilly's to get a 9mm allen.
    Oct 15 2009
    Gaithersburg/MD
    Yes ill be starting my search for that 9mm allen socket before I start the job
    Jan 14 2016
    Wilmington, NC
    This is why I talk about it in the video haha. O'Reilly auto parts luckily had one that worked perfectly. So stupid... every kit goes 6/7/8/10/11 etc. Super Lame
    Jun 12 2019
    MK5 Rabbit 2.5 5spd
    Natick, MA
    Audi has a p/n for the “special tool” of course, I think it’s like $38
    Jan 14 2016
    Wilmington, NC
    The socket from O'Reilly's was 8$ lol
    Jun 12 2019
    MK5 Rabbit 2.5 5spd
    Natick, MA
    Yeah about the same I paid when I finally found it at an autozone two towns away after calling multiple autozones, advance autos, caps and hardware stores
    Jan 14 2016
    Wilmington, NC
    Ouch
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    My pins were ******ed up so I picked up a set of aftermarket pins from Advance Auto. I no longer need the 9mm Allen for the front brakes. Also if you need new sensors they are only $10 ish from AA unlike the much more expensive AUDI OEM parts. Aftermarkets work just as good.
    I know the book lists a ridiculous torque value for the Brake Carrier to Wheel Bearing Housing Bolts but I have never tightened them to that value without any issues. As tight as I can with an 18 inch breaker or rattle them down with my 1/2 inch air impact. I have never replaced those bolts on any car I have worked on since 1985 as well. I have never used any form of Loctite on any car either for the caliper bolts.
    Those little bolts on the fronts that hold the spring and dust plate are easy to screw up as well. Mine are held in with a Heli coil kit at this point. I had M8 Heli coils on hand already from a previous repair on another vehicle. Those OEM bolts are M8 but I am not sure on the thread pitch, I just know that my coils were not the OEM pitch so I had to buy new bolts from Ace Hardware. $3 repair as opposed to new calipers.
    For the caliper cylinder compression tool I just use a large C clamp and the old pad.
    Jan 14 2016
    Wilmington, NC
    Quote Originally Posted by Valpo A7 View Post
    I figured most of the "torque Specs" for the carrier to bearing bolts just meant "effing tight", but I've found if I don't list the "proper" technique people get upset haha.
    My c-clamp didn't work for me, but it's kind of awkward. This tool wasn't expensive and was super easy to use so I'm not mad about buying it. It will work on my wife's car as well.
    Veteran Member Four Rings JWebb_C7_Comp's Avatar
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    This thread is great as was the video. Thanks for sharing!
    Oct 15 2009
    Gaithersburg/MD
    Found a 9mm hex bit at Autozone for $6......AA didnt have sh%t....i think i have all the parts, tools i need fore the install. just waiting on the pads and rotors....You guys this I should get replacement set screws?
    ordered my rotors and pads from Adams rotors
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    I got away with not replacing the set screws, but have ruined many in the past. Maybe I’m ham fisted, but i tend to strip them. PB blaster and a little luck may get you through the job.
    Next time I’ll order set screws and will have them IN CASE, just like sensor wires.
    Jan 14 2016
    Wilmington, NC
    Quote Originally Posted by JWebb_C7_Comp View Post
    If you think the set screw is rusted or potentially damaged then get replacements. I didn't replace mine
    What he said
    Sent from my Llama using Tapatalk
    Nov 27 2018
    Valparaiso, IN
    Are you guys talking about those little screws that "hold" the rotor in place? Mine got screwed up about 15,000 - 20,000 miles ago and I never replaced mine. I quit using the guide bolt as well and just line it up then lift the wheel into place. I actually broke that wimpy plastic one that comes with the tool kit and superglued it back together but have not taken it out of the trunk since. Tempted to buy a metal 1 off Amazon.
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    Yes; the tiny set screw on the rotor. They simply hold the darn thing in place while doing your work. I typically strip them and keep a couple spares because I hate lining everything up when the rotor can move. Having a metal guide would solve that problem, making set screw irrelevant.
    I just mentioned it to help make things easy.
    Jan 14 2016
    Wilmington, NC
    Buy 2 of the metal ones. Worth it.
