Results 1 to 3 of 3
    Established Member Two Rings Daemotrix's Avatar
    Jun 14 2018
    Prague
    2.8FSi & Turbocharger is it possible?
    Hi,
    I heard about engines where modders added a turbochargers, so I wanted to ask, if It is possible to add turbo to 2.8FSi (eng. code CHVA). If yes, is there anyone who tried that?
    Veteran Member Three Rings Burkeomatic's Avatar
    Feb 22 2021
    14 A8L 4.0T, 96 Corolla Wagon
    San Antonio
    Quote Originally Posted by Daemotrix View Post
    Hi,
    Most of us here don't know a lot about that engine. Is it possible? Most certainly. Thinking right off the bat, if the 3.0 supercharger would bolt in the intake manifold place, that would be a good place to start. You would need to get it tuned, and get some adequate sized injectors. The folks I have seen that have done turbo set ups, have done a single turbo mounted toward the back of the engine bay behind the throttle body. That would require a good amount of fabrication. But my best guess would be is if the 3.0t stuff would bolt up, it would probably be easiest for you to just supercharge it.
    2014 A8L 4.0T - DS1 Stage 4/JHM TCU, FE Axlebreakers, E85
    Jun 14 2018
    Prague
    Quote Originally Posted by Burkeomatic View Post
    I thought also about take a supercharger from 3.0T and put it on my 2.8, it should fits in place, but I heard about ECU of engine cannot work with it properly. I hoped that anybody tried that, I'm sure that I'm not first with this crazy idea.
