Need some words of wisdom. I am in a process of reattaching my manual transmission to the car and at the step, where I have to bolt the driveshaft back to the transmission flange. That's where I've discovered the marks that I've made before disconnecting the shaft are no longer on the transmission flange. These are the marks that I do have:
1. The propshaft has my marks, but no factory marks that I can find.
2. The transmission flange does not have my marks, but does seem to have two yellow dots, presumably a factory mark.
How do I align the two flanges? Is there a way to tell the location of the factory mark on the propshaft based on other signs? Also, how are you supposed to align a brand new prop shaft with an existing transmission?
The shop manual claims you can be at most 30 degrees out of alignment to avoid 'excessive vibration and damage to the bearing'.
