Results 1 to 16 of 16
    Junior Member One Ring
    Aug 08 2021
    US
    A4 Underglow: The Forbidden Dream HELP
    I recently bought an B8.5 A4 and a friend of mine gifted me LED Underglow. I want to wire the underglow to my rear fog lights since I don't use them that often anyway, and it will give me an easy on/off switch. I am going into this blind and need all the help I can get, any pointers, tips, or knowledge is very much appreciated.
    P.S: They are actual LED bars that I will be screwing onto the car, not floppy LED strips that'll have the adhesive fail in 4 days.
    Apr 08 2008
    Columbus, OH
    Find the fuse in the fuse box an add in a fuse tap for 3 bucks from autozone. Connect accordingly.
    Sent from my SM-G998U using Tapatalk
    Aug 08 2021
    US
    This sounds about 15x easier than what I was thinking in my head, thank you
    Veteran Member Three Rings DrGER's Avatar
    Aug 31 2014
    '17 Audi A4Q 6MT CYMC/RJN, '11 VW GOV TDI 6MT CJAA/LHD
    NW OH USA
    Quote Originally Posted by japanada View Post
    Front & rear fog lights are controlled directly by the comfort system control module -J393-, not the pushbutton switch in the dash. none of the exterior lights has its own switched fuse position.
    [See later post re center dash switch assemblies] --g
    2017 B9 A4Q P+ 2.0T 6MT Daytona Gray. Previous: 2014 B8.5 A4Q P+ 2.0T 6MT Monsoon Gray; 2009 B8 A4Q P+ 2.0T 6MT Brilliant Red; 2005 B6 A4Q 1.8T 6MT Cambridge Green; 1995 B4 A90Q V6 5MT Pearl White; 1990 B3 A80Q I5 5MT Crystal Silver; 1984 C3 5000S I5 5MT Montego Black; 1978 C2 5000 I5 4AT Helios Blue; 1977 C1 100LS I4 4AT Signal Green; 1974 B1 Fox I4 4AT Sahara Sand.
    Jul 16 2018
    Atlanta
    None of the rear lights are connected to any fuse. They are all directly driven by the J393.
    Your post says it's B8.5, not B8.0. But does not say if it's sedan or wagon (allroad). Nor if it's incandescent or LED tail lamps. Can't talk specifics without all the specifics.
    Do these aftermarket objects have a wattage or current draw rating?
    Apr 08 2008
    Columbus, OH
    Quote Originally Posted by Smac770 View Post
    Well damn. Maybe find an interior light you don't use and wire into them? I don't know the last time I used my interior lights other than the visor...that's just me.
    Aug 31 2014
    NW OH USA
    Depending on how invested you are in doing something like this, take a look at part #7 HERE.
    Something like this switch panel for the right (passenger) side: https://www.ebay.com/itm/333628012862
    Or this: https://www.ebay.com/itm/133743559371
    Version J includes all three switch positions.
    While I thinking of it & have the wiring diagram for 8K2-959-674-x open, terminal 1 (of the 8-terminal connector) goes to the left Parking Aid button and terminal 7 goes to the right window shade button.
    Aug 08 2021
    US
    It is a sedan and my tail lights are the stock LED, not sure if the rear fog light that is integrated into that assembly are incandescent or LED but i'd assume LED. As for the draw rating or wattage, I'll have to check when I get back home.
    Jul 16 2018
    Atlanta
    The only incandescent bulb on the US B8.5 LED tails is the reverse bulb. If you're aftermarket device is expecting a stable 12v supply, I think you need to follow DrGER's lead and add a toggle to the dash to use as a control mechanism, and leave the tail lights alone.
    The problem with the factory buttons above the climate controls are they are just momentary switches. The J519 makes note of the event and toggles the device state. The buttons do not latch. You'd need a latching relay connecting term 15 to the accessory, controlled by the button, to work - https://www.te.com/usa-en/products/r...?tab=pgp-story I say term 15 just to be certain the lights are only on when ignition is on; don't want the relay or control of it fritzing and passing term 30 endless until the battery is dead. But there's also plenty of undervoltage detection relays out there for cheap on Amazon, or pretty much anything you can make at the circuit level.
    Aug 08 2021
    US
    Quote Originally Posted by DrGER View Post
    not sure how easy the removal to get there will be, but i will definitely look into doing that because having a button in the center to turn the underglow on/off would be amazing
    Veteran Member Three Rings FourRingsC6's Avatar
    Apr 19 2017
    10’ A4 2.0T Avant “Imola Yellow” / 08’ S6 V10
    Upstate NY
    I hard wired mine directly to 12v since mine has bluetooth box that I can turn on and off with my phone.
    Jul 16 2018
    Atlanta
    Or add the stop/start version of the coin holder - https://www.ebay.com/itm/382585740626
    Aug 08 2021
    US
    If i were to add a stop/start coin holder would the port in the coin holder connect to an existing port below the coin holder or will I have to diy wire a connection to an open fuse that is ignition activated? hopefully my wording makes sense
    Jul 16 2018
    Atlanta
    You're going to have to add a fuse and wiring regardless. I was just commenting on a factory looking button you could add for control purposes. None of the dash/console buttons are intended to pass sustained current. Did you ever see how much current these things you have require? Where is going to be your ingress point between the outside mounted devices and the inside of the car?
    Something like this could be easy, just run it off the cig lighter, but I can't really tell how it manages the wiring. https://ultrabrightlightz.com/produc...on-dual-switch
    What would be cool would be to use the cig lighter port, it's already wired for 10A, with an insert that is push in for on pull out for off. Take the ground line and run it to your device instead. Assuming you don't use the cig port for your charger. Modification of something like this would be cool, https://www.ecstuning.com/b-ecs-part...636ecs06-01~a/
    Aug 08 2021
    US
    It didn't come with much info but from what I can gather from it, it requires a 12v source and has a current max of 6amps. and im not sure where im going to route wires into the car but i've been reading up on ways to do so. Im thinking of possibly going through the ECU, but i'm having trouble finding a source with a guide to do so. I also have to make sure the wires dont go anywhere near anything too hot that could melt them.
    Aug 08 2021
    US
    would it be possible to use the ami port to draw power?
