Results 1 to 4 of 4
    Junior Member Two Rings
    May 17 2021
    Utah
    Repair of cracked carbon fiber trim? An idea.
    I drive an S5 but posting here because the S4 is a much more common car and it's the same trim pieces.
    The shifter console trim on my car is cracked on the passenger side. I'm sure it's not particularly uncommon. I know that the new part costs $700 and I will never ever ever pay that much. Also won't pay the going rate for 2nd hand trim. Ain't gonna happen. Shifter trim is worth $50 to me, maybe $70 at the outside. I'll smack every piece three dozen times with a ball-peen hammer to achieve a uniform spidering of cracks before I break 3 digits for a replacement piece. I buy cars to drive them not to look at them.
    But that's not to say that a defect doesn't bother me.
    I have a friend whose hobby is boat repair. He spends a lot of time with fiberglass, carbon fiber, resins, etc.
    I was thinking about the fact that we are all well-acquainted with resin that has wetting and wicking properties sufficient to obscure a crack in safety glass when i asked him about this problem.
    He says he has, I forget the term, the epoxy that is specified for impregnating fibers under vacuum. And he has a really big vacuum pump.
    Has anybody actually tried this sort of thing? It *should be possible to draw some water-clear epoxy into the crack, cure it, and sand and polish back to a high gloss.
    Oct 02 2012
    Nottingham, UK
    What you are suggesting is perfectly possible - you need a thin water clear epoxy for the job, it is a good idea to try and flex the piece so the cracks are "open" when you fill it.
    Mar 31 2008
    eS-4
    CAL*SO
    Not a new idea..
    AS SEEN ON TV has a cracked windshield repair pen that does exactly this.
    May 17 2021
    Utah
    Quote Originally Posted by Fresh.S4 View Post
    Not a new idea..
    Yeah like I said - we've all seen windshield repair guys at work. It's just resin.
