What youre trying to do is damn near impossible.
This car has no crank locking tool so there is your first problem
You must undo the tension on the chain to get it off so who knows where your reference crank will be.
Your sprocket lock tool is the only tool locks the cams as the cams are attached to sprockets.
I guess you could line it up visually with the timing mark for crank on the lower timing cover. Lock the sprockets, then remove the chain.
You would then though have to remove the head bolts without removing the cam cover as that is holding the cams in place.
So yeah it could be done with what you have already.
I'd wonder why you think you have a bad head gasket though. I've never seen one fail ever..
Sent from my SM-G973W using
Audizine Forum mobile app
