Results 1 to 21 of 21
    Jul 30 2021
    Fort Myers
    2018+ 3.0T SQ5/S4 coolant temp to high Fix (future reference)
    A valve can fail on top of the passenger cylinder head (N649) with a message on the dash coolant temperature to high. The valve is the coolant pump switching valve, The vehicle will overheat if driven. You can test this by removing the vacuum line on the front of the valve and plugging the vacuum line. If the message is gone and the engine is no longer over heating, the valve is faulty.
    The valve is the correct solution however the part isn't listed correctly under any part distributor and is nearly impossible to find.
    The part number for the valve on the vehicle is 037906283. Which is listed as a secondary air injection valve on FCPEuro for $27. And you can also buy it from oriellys auto under interchange part number 667-108 for 149.99 I can confirm both parts are the same number, identical, and work.
    Part 037906283 has been used in tons of audi/vw vehicles over the years but still says it won't work when you put in anything 2018+ for a vehicle search... this is incorrect and it is the same part for the 3.0 Turbo sq5/s4 (not supercharged)
    Part is easily changed on top of the passenger cylinder head. Slightly in front of the waste gate solenoid under a wire loom.
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    Super interested in the background info behind this. Is there another thread discussion about this somewhere? I've ran into that dash exact warning a pair of times recently. In both cases Audi diagnosed it as a bad thermostat and a trapped air pocket, respectively.
    The issue hasn't come back since, but it would be great to read up on this further if it does.
    For reference: Wondering if it has any correlation to the issues in this thread.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Jul 30 2021
    Fort Myers
    Yes possibly, it happend to me when I first bought the car. Seems like the valve will stick then eventually just completely fail.
    There is another thread in the s4 section that's talks about this exactly. Check it out
    https://www.audizine.com/forum/showt...ature-too-high
    May 10 2023
    austin. texas
    Cool Some more info on overheating
    Quote Originally Posted by Broke18SQ5 View Post
    Howdy:)
    Just finished repairs on 2018 Audi S4 premium plus 3.0T. The coolant control valve described above was sticking in the open position. Verified with vacuum gauge in line between vacuum valve and coolant pump. Monitored power and ground to valve, and after the ecm switched the valve off (coolant temp. approx. 194 degrees as seen on scantool ) the vacuum did not release as expected. The vacuum valve was indeed stuck open. Upon inspection I could see some oily ooze under the valve (saw someone post a pic of this in another thread). Yes, the correct repair includes the valve, but that ooze came from somewhere (the coolant pump most likely). Also noted that when the vehicle was overheating due to the valve stuck open, the ecm stored a rationality code p1c1b - water pump mechanical malfunction. When this code sets, the message to check the coolant level appears in the MFI, even if the reservoir is full. Once the problem is fixed, and the fault is cleared, the message will be gone. Make sure no faults are stored before assuming your tank / level sensor is faulty. I replaced the coolant pump, control valve, and thermostat (since i was in there)... also the seals for the coolant pipes were not available separately -- replaced both pipes. I couldn't find any useful information on alldata or identifix, and these thread were helpful in thinking through the repairs. So THANK YOU!!! and i hope these other nuggets are helpful to the next person
    oh yeah, you dont have to perform service position to do these repairs. the trickiest part was removing the air intake tubes. I used a Skewdriver (or also called offset screwdriver, Angle drive from Window Removal Set -VAS861001A- or Offset Screwdriver -T40398-) plus two bit driver extensions to get down there. The tube to the turbo inlet lower bolt was made easier with a ball end t30 bit.
    Aug 14 2023
    Somerset pennsylvania
    Quote Originally Posted by grimspd View Post
    Howdy:)
    Hi! was wondering if the coolant control valve is something that is manageable to fix at home or would i be better off finding a reputable shop near me? closest one is over an hour away.
    Dec 28 2020
    Quote Originally Posted by baggedB9 View Post
    It’s a 10 minute job. Super easy.
    Junior Member One Ring
    Apr 20 2016
    AZ
    Hoping someone can help me with this 10 min job, as I can't even find the bugger after 30 mins of searching. I have this same "Coolant temp too high" warning, and bought the switching valve (037906283) listed above. I can find several people posting pics of their old part, but can't find any references in forums or online on where to find the part in a 2019 RS5. I attached a pic below of the engine bay (stock pic) with the location of the coolant reservoir marked, and am hoping someone might be able to point out where it likely is, or if it's a bear to get to.
    https://imgur.com/XLLXiae
    Dec 28 2020
    Passenger side on top of the valve cover on the EA839..
    Apr 20 2016
    AZ
    Oh man, thank you so much! I must've traced my hand over this about 10 times. So where do I send the case of beer??!
    Apr 20 2016
    AZ
    Sorry, last question...It looks like there's a bracket holding hte solenoid in place, right where the tip of your prybar is. Is there certain method to detach it? I'm trying not to strongarm it, and break something. Thx!
    Dec 28 2020
    It’s been a while, so the memory is a bit fuzzy, but yes I believe it’s a simple clip that you can just push up on with a screwdriver or similar tool while wiggling the valve loose. Look at the replacement part to get an idea of the clip and direction you need to pull..
    Veteran Member Three Rings JonnyBravo!'s Avatar
    Oct 26 2014
    2018 SQ5 | 2017 A3 e-tron
    California
    Just wiggle the valve off. It’s not really a clip, so it kind of slides off. I’ve replaced that valve three times by now - it’s super easy.
    Apr 20 2016
    AZ
    Awesome, thanks guys! Gettin' after it now...Keeping fingers crossed this solves the issue.
    Apr 20 2016
    AZ
    Happy to report that this could very well be the best $18 I've ever spent! Did some long test drives, opened it up a few times, and temps all look good, and no warning light. Thanks to all the good people on this thread, much appreciated!
    Btw, here's what the solenoid looked like...pretty nasty: https://imgur.com/q0NBWBj
    Aug 14 2023
    I gotta ask where you ordered your valve from? i found one on oreillys and fcpeuro but they look slightly different. Thanks in advanced! glad you got your unit back up and running.
    Junior Member Two Rings jmvidaillet13's Avatar
    Jan 21 2018
    Tampa, FL
    I bought mine from Amazon:
    037906283C Vapor Canister Purge Valve for Audi A3 A4 A5 A6 A8 Q5 VW Beetle CC Passat GTI https://a.co/d/1ZRpTSO
    This one is OEM I believe:
    https://www.fcpeuro.com/products/aud...oaAgkJEALw_wcB
    Thanks,
    JM
    Sep 04 2023
    Thank you!
    I too recently received the temperature warning on the dash. Pulled over and the radiator fan was spinning at full speed all while oil and cool temperatures were reading normal.
    Popped the hood and everything was cool to the touch, no observable coolant leaks or smells. Hopped back in the car and drove home. Next day I start up, same thing happened. Same message, same fan at 100%, engine cool, no leaks or smell of coolant.
    Broke out vcds and scanned. Only errors found were for the terrible front speakers. Posted on 034 FB group as I’m running stage 1 E85 on my 2018 S5 sportback. Everyone seems to point to a water pump problem.
    In everything if read online, everyone has the water pump and thermostat replaced, but only to still have the same issue a day later. Because of that I replaced this same part. Bought the part for $50 on Amazon. It’s actually manufactured by pierberg, but doesn’t have Audi rings.
    Long story short, replaced this in about 30 minutes, and the car has been running flawless for the last 500 miles. I was ready to drop off at Audi, but I felt like replacing this cheap part first was the better route since it’s what appears to fix the real issue. The real issue is a failed sensor, now a bad water pump! So many owners have been screwed out of thousands of dollars because of this shitty diagnosis.
    Howdy:)
    Aug 14 2023
    hey guys, i changed this valve thanks to y’all’s knowledge, ran like a champ for close to 600 miles but today the check engine light came on, may or may not be related. regardless i was wondering if there was any at home scanners yall reccomend, closest audi shop/dealer is close to an hour away. thanks!
    Junior Member Two Rings B9Gee's Avatar
    Apr 20 2022
    Audi A5
    Texas
    Get OBd11 scan tool...it can scan and you can buy credit to turn off and on certain features.
    Sent from my SM-S908U using Audizine Forum mobile app
    Apr 08 2011
    '21 SQ5 & '16 Golf R
    NoVA
    Quote Originally Posted by B9Gee View Post
    Or spend a little more and get a VCDS cable from Ross-Tech. It’s a little more up front but there are no subscriptions, no credits and they have lifetime support that is actually really good.
    OBDEleven’s support is utterly useless.
    iain
    Aug 24 2014
    Ottawa Valley, Ontario, Canada
    FYI there's not supposed to be ANY coolant in that valve, it's a vacuum valve.
    Coolant in that valve means you have a coolant leak, likely the vacuum operated shutoff valve on the front of the engine beside the thermostat.
    Cheers.
