034 Procedure - Lowering entire subframe at once(Clickable link):
PROS:
- Can replace both mounts more quickly. (Is it easier though?)
- No need to remove vacate/replace refrigerant to remove AC compressor
- No need to remove drain oil to remove Oil Cooler
CONS:
- Need to get an alignment after job, to correct camber.
- 3-point engine support recommended. Harbor Freight support might not cut it.
- (Lowering the entire subframe may cause increased stress elsewhere in drivetrain)
Factory Procedure - Replace one mount at a time(Clickable link):
PROS:
- No need to get an alignment afterward
- Can use Engine support bar
CONS:
- Need to remove AC compressor (unknown procedure and replacement bolts)
- Need to remove Oil Cooler (Gasket + bolts needed)
- (Takes more time?)
Also, Audi recommends replacing the motor mount bolts and subframe bolts. Is this necessary? Any other tips and tricks from experience? Thanks All.
