Originally Posted by
George@BMS
The car does not continuously store data but freeze frames of when faults are triggered. There hard triggers like speed, rpm, torque are very few. The ECU would run out of data storage otherwise.
I'm a dealer tech, I know how it works.
I also know what data a freeze frame of a catastrophic failure fault looks like, and I'm 100% positive it's not all values the JB4 adjusts. If you are fooling boost pressures, you are in places in the required airmass tables and torque load values you normally wouldn't be. I've done tuning, I've done warranty work, trust me, if they want to find out if you had a piggyback, they could. The reality is, it's not often worth their time, and beyond asking for a scan of the car, which will show if it's got a tune but won't show a piggyback, they don't really investigate unless there is some major reason to. I'm just offering both sides of the coin, I still agree a piggyback is very hard/nearly impossible to detect and much easier to hide than a flash tune.
