Results 1 to 18 of 18
    Junior Member Two Rings
    Jul 23 2015
    Birmingham, AL
    2013 S6 needs new transmission, dealer & independent says I must buy new from Germany
    Is this true? I've now been told by two shops that buying a used DSG and putting it in my car is not possible and I must buy from Germany, $15,000 parts and labor.
    Which obviously I won't do, the car running isn't worth more than $22,000.
    I cannot imagine a scenario where Audi makes a transmission that commonly fails before 100k miles and literally locks you out of any solution other than buying a new one for $15,000 and hasn't already faced a class action lawsuit for it.
    *Edit: So after calling around, including talking with Tioga at Automotive Solutions in Chapel Hill, NC, it's not that the transmission can't be fixed or that there aren't some likely culprits. The issue is that it's likely 1 of 2 things: mechatronics unit or clutch packs. If you don't guess right the first time, and end up doing both, then you're into it for 9-10 grand. And then there's still not 100% guarantee that you're going to fix the problem. So you're risking, even if you get it on the cheap, 7 grand to avoid spending 14 grand for an entire new box. And it's just not worth the risk for most people.
    I cannot recommend Tioga enough. Including for out of state folks. The guy was amazing to talk with and knows these cars inside and out. Also Franklin Automotive in Birmingham, AL. I was frustrated at first with the news, but they spent the time to walk me through my options and I felt like they were dealing with me straight. Now to decide what to do...
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    first, what is wrong with the transmission...
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Apr 08 2008
    Columbus, OH
    What are the issues your having that they are saying a new trans is needed? Normally a mech rebuild solves mose issues
    Sent from my SM-G998U using Tapatalk
    Jul 23 2015
    Birmingham, AL
    I don't believe it's a mechatronics issue.
    Drives fine for about 20-30 minutes, then low gear 1st or 2nd it slams into gear pretty hard. Eventually it stalls entirely. Let it sit for a few mins it'll start again.
    The first time I had a problem, it overheated and threw a warning and I could smell transmission fluid. It was missing low gears/slamming into low gears. I'm trying to find the code it threw but it was basically "overheat due to 2nd gear failure" or something like that.
    The shop I took it to has done a number of mech replacements and said this wasn't going to fix it. And that they've never had one stall like that.
    Feb 13 2004
    Silicon Valley, CA
    Try to find a used one from a car with low miles being parted out. I had to replace the transmission in my B6A4 (I know, different car) when it had about 95k on it. Transmission was going to be $8k installed. I found a used one for $1,500 including shipping from a donor car that only had about 30k. Shop put it in for $500. Not saying it will be that cheap, but its going to be less than $15k.
    - - - Updated - - -
    Send xFvse a PM, he might be able to help you find one.
    Kevin - Moderator, Audizine
    Veteran Member Four Rings OlyS6's Avatar
    Nov 22 2016
    Olympia, WA
    You can absolutely use a used transmission. The mechatronic unit itself contains the TCU, and will need to be in a specific series in order to work with your car, so it would be best to find another 2013 S6 that is being parted out for whatever reason. You could go with both a new mechatronic and new clutch pack (I did this recently) rather than an entire transmission. Audi will not service either of these, and will go straight to an entire new trans. Fine if you're under warranty, not so good if you're not.
    2016 S6, mythos black, RS7 turbos, MRC inlets |Akrapovic exhaust| AMS downpipes and intercooler |Eventuri intake| Loba HPFPs |Tial wastegates| Eurocode sways, end-links, and AK | Audi CCB| HRE P103, 20x10 | RS6 grille| Neidfaktor CF mirrors, diffuser, and steering wheel| Blackvue dashcams| Escort Max CI 360 | RS6 LED headlights, OEM Euro tails |Sound: Navtv Zen-v preamp, Helix DSP Ultra, JL HD900/5 driving JL10W3 sub and Hybrid Audio speakers.
    Jul 23 2015
    Birmingham, AL
    Quote Originally Posted by Stubek View Post
    - - - Updated - - -
    What they're saying is that because of Audi software restrictions they literally can't swap with a used one. I.e. Audi has set it up so that no independent can put in a used transmission forcing you to buy a new one.
    - - - Updated - - -
    Quote Originally Posted by OlyS6 View Post
    What did your swap end up costing you?
    Veteran Member Four Rings 09S5's Avatar
    Dec 04 2015
    A8L, 4X4, c6 VETTE, New CTS-V
    TN
    Maybe useful
    Good luck brother with this task.
    Sent from my SM-N976V using Tapatalk
    Nov 22 2016
    Olympia, WA
    Quote Originally Posted by bamagrad03 View Post
    - - - Updated - - -
    I sourced a new mechatronic for ~$1500 and an upgraded TVS clutchpack for $4k (you can get a stock one for much less). Labor overall was about $2k. And your shop is incorrect about not being able to use a used one. The mechatronic must be compatible, and then you will need somebody who can reflash everything so the car can talk to it.
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Brutal. But your edit in your initial post seems to indicate that repairs of some sort are possible. An internet search turned up Eagle Transmission in Mesquite TX and Precision Transmission in Ormond Beach FL. Both claim to be familiar with and able to rebuild Audi DSG transmissions. Maybe worth two calls for more opinions?
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Established Member Two Rings vrod's Avatar
    Oct 02 2018
    Germany
    - - - Updated - - -
    That is complete BS if I may say so. If you bought another used transmission, you could even just put your current TCU into the new transmission, do some calibration and be fine.
    It most likely has to do with component protection and immo adaption which can only be done with ODIS.
    I have already been through an entire swap with an used mechatronic + transmission myself and all I needed was ODIS (which I am lucky to have).
    Established Member Two Rings pointblank9957's Avatar
    Jul 12 2019
    2014 Audi Allroad Volcano Red, 1998 A6 Avant Casa, 1997 A6 Avant Emerald
    Sheboygan, WI
    Quote Originally Posted by vrod View Post
    This put my mind at ease (as much as it can be with an out-of-warranty transmission replacement). The shop doing the repair told me it looks like my mech was on fire... so i'm doubtful the TCM lived
    2014 A4 Allroad 1/49
    1997 A6 Avant 1/141
    1998 A6 Avant 1/10
    Kujispeed Products:
    Audi C4 Avant LED 3rd Brake Light
    Audi C4 Sedan LED 3rd Brake Light
    Delta CC Bluetooth audio streaming Integration
    Established Member Two Rings LifetimeAudi's Avatar
    Nov 30 2020
    Durham, NC
    If you end up needing a used replacement transmission we may be able to help, we've got a couple of NSK 5C1 trans here
    Veteran Member Four Rings fastboatster's Avatar
    Apr 23 2019
    2010 Audi A4 3.0T, lol
    CA
    you have a GECKO subscription, don't you?
    Senior Member Three Rings akingzkid's Avatar
    Mar 04 2018
    2006 Audi A6 3.2, 2014 Mercedes E350
    Virginia
    2013 A6 3.0T Prestige (LED pkg, cold weather pkg, cooled seats, innovation pkg (HUD, top view camera), ACC, sport pkg, 20" rims, HPS short ram intake)
    2006 A6 3.2
    Sep 22 2022
    Western MA
    Quote Originally Posted by LifetimeAudi View Post
    Still have any of these available?
    Oct 02 2018
    Germany
    Quote Originally Posted by fastboatster View Post
    No I have a friend who does a ton of remote ODIS online coding so he could do it.
    Went through mechatronic fix, mechatronic swap, tcu swap and then gearbox swap.
    Convinced a gearbox workshop near me to only do the physical swap, I would do the coding stuff.
    The 1700€ gearbox I bought back then still works to this day after well over 50tkm. Old one is still at the workshop waiting to get refurbed :D
    Veteran Member Four Rings Audibellybutton's Avatar
    Jun 28 2019
    California
    - - - Updated - - -
    I’ve seen people so used dsg swap and clone/program tcu with Pcv flash. Look into that it’s not as complex as you think there’s even some videos on YouTube. I would 1000% get a used one if I were you. Try to find a good one with low miles if you can
    C7 Audi A7 Prestige 3.0t (RIP) - Dual Pulley E40 , Turtle TCU , Ported Blower, Meth, Porsche 997 TB, Merc Racing Heat Exchanger, CWA-100, RKX Silicone Intake hose, RS7 Airbox, RS7 LPFP, JHM 207 pulley,SRM Driveshaft Upgrade, H&R Springs, 034 Drivetrain inserts, Vossen VFS2, RS7 Steering Wheel, Autotech HPFP
    C7 Audi S6 Prestige 4.0t (Current) - ZF8 Swap, E85 tune W/ FE STG2 Turbos, WMI, Merc Racing HX, EMP Coolant Pump,GFB DV+,LPFP upgrade, ECS Inlets, TS Gates, Exhaust
    IG:@stolens6
