Results 1 to 8 of 8
    Oct 22 2012
    LA, CA
    New Q7 = no mo snow chains?
    I'm back in an audi with a 2021 q7. Dealer told me, and made me sign an acknowledgement, that normal snow chains will damage the undercarriage or something. Cant use em.
    So with a winter trip to yosemite already on the calendar I've started looking for a solution. Is there a lo profile set of cables that people use with success?
    FYI, im in LA so summer or all seasons for me day to day. I'm fine with dedicated snow wheelset shod with a 3peaks tire but now I see that even with awd and snow tires caltrans can in fact still require chains depending on road conditions so it seems I need to have a set of something in the car at least.
    What are yall using for chains/cables?
    Veteran Member Four Rings Zolli's Avatar
    Sep 29 2016
    2011 Q7 TDI
    Scottsdale, AZ
    I bought a set of chains last winter for a trip up to the AZ Snowbowl, but I ended up not needing them, at least not for any of the driving around I did. I went effortlessly through fluffy snow and packed snow, though I don’t know how densely. Only one teensy slip and the Quattro corrected it immediately, awesome.
    When turning the wheel and it is at nearly full lock, I noticed the corner of the tire gets maybe within a 1/2” of the front fender liner. I can see how chains would wreck that. I’m in a 4L with 21” wheels and Pirelli trash bags I mean tires. Those are summer tires and that’s what I took to the Snowbowl. The wheels are like 10” wide, so that probably contributes to the tight clearance.
    You could consider stud-able tires, but if you got some 3-peak tires, you’d probably be fairly unstoppable. A set of snow wheels/tire combo will probably be about 8” wide at the rims, so that might help.
    I’ve only been to Yosemite in the summer, so I don’t know how crazy that entrance road gets in the winter, but I imagine it will be decently prepared (along with all the others) for passenger vehicle travel. I have been to the Grand Canyon in the snow, and the Q7 has been a champ.
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    At least OP gave us more background information here than he did on Reddit when posting the same question. Smart ass answers like snow and ice to relevant background questions will return you some pretty shitty responses on general forums like Reddit.
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Nov 12 2015
    Oregon
    Fwiw:
    I just came out of a Tdi Q7. Had summer tires on 20s. Never got stuck where I couldn’t get out. And we drove all around the Mt. Hood National forest. Unless you’re doing something really dumb, I think you’re fine.
    My build log
    Oct 22 2012
    LA, CA
    To be clear, I'm not looking for chains because I want them for traction. I'm confident I'd survive. But the question is caltrans requirements to pass check stations. If I need to have them on or at least in the car then I'd like a set that won't damage the car.
    Oct 22 2012
    LA, CA
    I'll look into the peerless z6. That seems to be the lowest profile I can find.
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Do you need “chains” or is an “Autosock” sufficient?
    https://autosock.us/california/
    Senior Member Two Rings misc720's Avatar
    May 04 2009
    socal
    Quote Originally Posted by ekkthree View Post
    Sorry for digging up an old thread, but did you ever try these chains and did they work?
    Anyone else have experience with chains that work? I have a 2021 Q7 with 255/55r19.
