Originally Posted by
mrb5_supra_wrx
found that had a few fuses out thanks for the help tho guys. Unfortunately have an issue now that since i got the coolant pump working again my cooling fans come on every time i unlock my doors or turn my ignition off which is weird any insight?
are you tuned? what tuner? 034 and ie have modes that trigger the fans based on the cruise control stock forward or back condition to force fans to run even when stopped to cool the heat exchanger fluid more. i'd guess these would also run on "car wakeup" triggers just like the supercharger coolant pump does in these modes or when you cut the pwm wire for the pump (middle wire)
otherwise fans running 100% with ignition power could be a bad pwm signal from the fans (cut wire corroded connector or something else that went bad) and the fans when they don't have pwm signal say "crap something is wrong, better just go to 100% to be safe no matter what and not overheat the engine" obviously failing safe like that is better than if the fans died with no pwm.
