Picked this up with my 996. This is a must with the 996, figure it made some since on these cars with the oil screen issues.
For those that haven't done this. You take your old oil filter and a sharp knife and cut it open. Then you can pull the pleats apart and see what type of debris the filter is catching. Gives you a little insight into your engine for 5 minutes of work.
First cut the outside, all the way around. Takes a little force as there is a metal mesh in there...push under control...keep legs/arms clear:
Then cut across the middle so you can open it up:
When done it will look like this:
The 4.0T is an outside-in filter. So the debris will be caught on the OUTSIDE of the filter. This is my filter after I did my turbo swap from the failure. I ran this oil a little bit after the new turbos before changing oil This oil had about 2500 miles on it, a touch over a year old. Here is what I got...
If you look at the pic close, we got some black debris and just a few shiny pieces. Here I highlighted a couple of the shiny pieces.
This is aluminum, just showing engine wear. Typical stuff here. Nothing that is worrying, not many pieces, pretty small. Looks good.
The black stuff I am not sure about. If it was my 996 I would say it was plastic from the cam guides. But in the 4.0T, it doesn't appear they have black cam guides, so that likely isn't it. There is not that much of it. But enough. Here is a closer view...
Pretty small stuff. Looks a bit like the gunk in/around the PCV in these cars. Also looks a lot like the stuff some people find in their oil screens. At this point I am going to call it PCV stuff, unless someone else has a better idea. We'll see if I just stirred a bunch up swapping the turbos...find out when I check on the next oil change.
Anyone changing oil, feel free to cut your filters open and post your pics. It would be good to get a thread going to see what kind of debris people are catching in these engines.
