I recently upgraded my stock B&O sound system with new subwoofers in my 2019 S5 Prestige Coupe. Since the install, I.have been having intermittent issues with the key fob not being detected. I have already replaced the battery, and ruled that out as the cause. I can unlock the car by touching the inside of the handle, but I cannot lock by touching the outside of the handle. During my drive to work the "key not detected" issue will happen about 2-3 times, lasting a few seconds to a few minutes each time. The key is always in my left pocket, my phone is plugged into the center console (nothing else in my left pocket, other than the key ring and a couple keys). I have tried to catch it on my obd11, but get no codes for that.
I have also had a couple issues with the new sub. A few times when I turned the car on, the sub wouldn't come on. Ran the obd11 and it said "B130C11 - Double subwoofer speaker 1 Short circuit to ground" a few times, both static and intermittent at times. Once I cleared this code, the subs come back to life. I'm thinking this issue is because the stock sub was unplugged during install. Is there a way to solve this other than installing a relay to the stock sub?
But I cannot figure out this key issue. Any thoughts?
