Results 1 to 20 of 20
    Dec 13 2018
    1965 Corvette
    Carlsbad, CA
    22" Wheel - Correct and Best Tire Size?
    I have a 2019 Q7 Prestige that came with 21" wheels. I found and purchased a set of 22" Audi OEM wheels that came from a Q8. I am now fitting these wheels with new tires so I can add them to my Q7. I went to Discount Tire yesterday and they said I need to go with 285 / 40 R22 tires, because I need a set of tires with a load rating of at least 110. They said they are concerned about rubbing but will fit them after they arrive to assure there is no rubbing.
    Does anyone else have experience with this issue? What tire size should I use?
    Thanks.
    Hikerneil
    2019 Q7 Prestige - Adaptive Chassis, Luxury Package, B&O Stereo
    2023 Corvette Convertible
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Tire rack lists the following oem tire sizes. My impression was the q8 22s are the same as the q7, thus the 285/35-22 XL is ok. Are the q8 wheels wider?
    Apr 29 2014
    2017GLS550 ST1
    Area with Bay people
    I'm on 285 40 22 for summers, and they're awesome. Lexani Lx20 for some 125$ per tire. I pulled 30k of awesome driving. To be replaced with superior Toyo Proxes ST3s, off from GLS.
    On 22X9.5 wheels, i think 22x10.5 would be just perfect, bit of extra poke, without spacers. Run on 22x10.5 on the other rig and feels more planted.
    Chirboiz,
    Bob
    Sent from my SM-G998U1 using Tapatalk
    For sale: SQ5 springs
    AKA BobSF
    Veteran Member Four Rings audirings4's Avatar
    Nov 23 2011
    SQ7
    DFW
    As mentioned above and on the other forum 285/35/22 is the OEM size. If this shop says otherwise you need to go elsewhere.
    Veteran Member Three Rings 4-ring-sleepers's Avatar
    Feb 17 2018
    2018 SQ5/2021 SQ8
    Central FLorida
    I run 22x12 et20 bcforged with 305/45/22 rubber tight fit but looks and drives great. 20210806_185257.jpg20210806_185405.jpg20210806_185409.jpg
    2018 SQ5 Prestige - AWE Carbon Intake, AWE Touring Resonated Exhaust, RedStar Exhaust HFC Downpipe, Turbo Systems Stage1 Hybrid Turbo, Forge Motorsports FMIC, Forge Motorsports Transmission Insert, Cete Active Suspension Controller, EPL Stage 3 (beta) tune, Carbon Fiber (w/alcantara sides) Steering Wheel, Vorstiener VFF-110 20x9 et35 Zara Gray, APR 10mm Spacers, Ti extended Lugbolts, Suntek Ultra PPF, Cquartz Finest Reserve, Full Cquartz Interior, Formula One Stratos Tint 30%
    Dec 13 2018
    1965 Corvette
    Carlsbad, CA
    Thank you to the folks that replied above. My tires came in and the Pirelli 285/40/R22's fit perfectly. I have absolutely no rub. I am super happy with the ride quality. I'm actually happy that Discount Tire stuck to their guns on the sizing of the 40's over the 35's as the ride quality has not been harshened. I will put up with the 2-3% difference in mph displayed on my odometer for now (I usually have WAZE displayed on my phone anyway and it shows the true actual speed). I am also really happy with the way the tires and wheels fully fill the wheel well now, it's exactly the look I was after when I bought the 22's.
    Thanks again.
    Hikerneil
    Nov 23 2011
    SQ7
    DFW
    Do you have any warranty left? If you have any drivetrain issues Audi will point to the non-OEM tire size.
    Dec 13 2018
    1965 Corvette
    Carlsbad, CA
    Audirings4: Interesting. Never thought of that. Is that because of the increase in overall diameter, or would it apply to any change away from OEM setup? For instance, what if I had kept my 21's and switched from 285/40/21 to 285/35/21? I wonder how many people are aware that that would be an issue?
    What is the technical reason for this being an issue? I could understand if I had gone with a staggered approach with different sizes on a car with Quattro drive, but if all 4 tires are the same size what difference does it make? Audi does sell this car with a 22 wheel option.
    Hikerneil
    Veteran Member Four Rings Zolli's Avatar
    Sep 29 2016
    2011 Q7 TDI
    Scottsdale, AZ
    Quote Originally Posted by hikerneil View Post
    To my understanding, no technical reasons; just dealer excuses. You make a good point about the 22” option available, so I think you would have a good argument if you needed to make it.
    Veteran Member Three Rings pismojeff's Avatar
    Apr 10 2004
    Bend, OR
    Thanks again.
    This is a beautiful setup. Exactly what I am looking to do with my 2017. Is your suspension modified at all? Looks perfect!
    2017 Audi Q7 3.0T
    2000 Porsche 911 Carrera
    RIP: 02 S6 - H&R springs, 19 BBS LM reps, RS6 front my ride
    Dec 13 2018
    1965 Corvette
    Carlsbad, CA
    Quote Originally Posted by pismojeff View Post
    My car's suspension is totally stock, no changes. I'm super happy with the results.
    Hikerneil
    Senior Member Three Rings ericA6's Avatar
    May 03 2012
    Dallas, Tx
    What’s the specs on these 22” wheels? Do you have part #? Great look!
    Current - '10 A4q S-Line
    '16 Honda CB500F - I like my bikes naked
    Past - '05 A6q 3.2L
    May 21 2010
    Quote Originally Posted by audirings4 View Post
    I've had several Audis and almost never run the same size tire that comes on the car. SQ5 came on 255.....went 275. Went 285 on last SQ5. Also lowered a few of them, mostly on the dealers recommendation.
    Nov 23 2011
    SQ7
    DFW
    Quote Originally Posted by Wilbur View Post
    Yep.. I’ve had a number myself and almost always upsize but I’ve also never had any drivetrain issues because I don’t keep my cars for long. If I was in for the long haul I’d be more cautious because the dealer could point to my non-OEM tires sizes and say they caused the issue.
    Apr 29 2014
    2017GLS550 ST1
    Quote Originally Posted by 4-ring-sleepers View Post
    That is amazing! But that is a Sq7/8?? Wheel well looks bigger. I tried to squeeze in 285,/45/22 on 18Q7 4M, buy would rub in fronts. Next week i go staggered 285//295/40/22 F/R. 22x9 22x10.5
    AKA BobSF
    Dec 13 2018
    1965 Corvette
    Carlsbad, CA
    I purchased the wheels from a Q8 owner. The wheels are Audi OEM from a 2020 Q8. The part number that is cast on the backside of the wheel is - AU001 BBS, E 9.5Jx21H2 ET31
    Hikerneil
    May 03 2012
    Dallas, Tx
    Thanks! I was able to find the actual part number: 4M8 601 025 Q
    These are sharp on the 4L Q7!
    Past - '05 A6q 3.2L
    Feb 17 2018
    2018 SQ5/2021 SQ8
    Central FLorida
    Quote Originally Posted by SQ57 View Post
    Wheels fit with very tight tolerance on suspension knuckle. Basically a credit card would fit between. If it does not touch when mounted, it will never touch. I ended up going with 5mm spacers F/B to flush it out a lil more 20210820_164118.jpg
    Apr 29 2014
    2017GLS550 ST1
    22x9 285 40 22 Toyo Proxes ST3 Front
    22X10.5 295 40 22 Toyo Proxes Sport Rear
    No need for rear spacers.
    AKA BobSF
    Nov 03 2007
    A6(C7.5), Q7(4M), Q5, A5(B8.5), Escalade(MY08/MY15), H2, 360
    Who told you that lie, stop saying things unless YOU, yourself have experienced it.
