Hello,
I have a problem with my 2008 A4 2.0T engine. After a few minutes idle oil is getting "milky" and coolant tank is empty. Thought it's a head gasket and replaced that one. No help. Then start thinking it's a cracked head. Went to a scrapyard and got a head out of other 2.0T engine.
Bolt everything back together and started it once again. And after a few minutes dipstick was "milky" again and tank was almost empty.
Kind of hard to believe it's an engine block what is cracked because it's cast iron, not aluminum. Can it be a bad turbo or is there an oil cooler somewhere which
could cause this problem?
