Results 1 to 3 of 3
    Active Member One Ring Cars with Sonduren's Avatar
    Nov 02 2020
    Ontario
    Took the R8 V8 to the drag strip - need advice
    I finally had the chance to take my 2008 Audi R8 V8 to the drag strip after 3 years of ownership. I have the gated 6-speed manual, stage 2 tune + custom exhaust and in 3 runs only managed to get a 13.2-second quarter mile. I have the Michelin Pilot 4S tires with 305s in the back and I still seemed to be struggling with traction. Any advice on how to launch the manual cars? I turned off launch control as well and tried dumping the clutch at 3K RPM.
    I would expect to be running in the low 12s? I had a passenger as well on the runs. I will say, banging out that gated manual transmission on the strip is priceless, even as a 960HP GTR spanked me 😁
    Jan 14 2009
    Audi's
    Nice video!!!!
    Senior Member Three Rings 8STTRS's Avatar
    Jul 28 2021
    Navarre, Florida
    A lot of that will boil down to track prep, temperatures, tires, density altitude, etc., etc. And suffice to say but, you more than likely would have hit a 13.0 or even a 12.9 sans the passenger. Every little bit counts. Next time you go out, lower your tire pressures and do a quick clutch dump after the water box to clean off the tires and maybe get a smidge of heat in them, then stage your car and launch it. Hopefully, that'll help.
    2018 Audi TT RS
    JDY Next Gen 6670 coming soon (shooting for 975-1kwhp on low boost).
