Results 1 to 40 of 40
    Jul 01 2012
    14 B8.5 S4, 90 Toyota Supra turbo (575 whp), 02 Subaru Wrx (stock atm),
    North little Rock, Ar
    Wtb hemi throttle body adapter IE,Ultracharger,etc
    As title states looking for one of these throttle adapter plates, or pipes from any company thanks
    Veteran Member Three Rings jcoleman_11's Avatar
    Apr 21 2016
    Toronto, ON
    Quote Originally Posted by mrb5_supra_wrx View Post
    If you can wait a bit, 034 is about to release theirs.
    Jul 01 2012
    yea with how theyve said prob will be another few months or towards the end of the year
    Mar 07 2021
    Asheville
    Hunter Trimble has one for sale as well. A cheaper hemi TB kit.
    Mar 31 2008
    eS-4
    CAL*SO
    Yea hunter is selling kits for $390 on fb page
    Veteran Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    2007 Porsche Cayman | 5MT
    Apr 21 2016
    Toronto, ON
    What are the odds, literally dropped today.
    Was hoping they were gonna sell just the adapter and not the throttle body too.
    Nov 20 2015
    West Palm Beach FL
    Quote Originally Posted by jcoleman_11 View Post
    They are selling it without the throttle body as well.
    https://store.034motorsport.com/034m...y-adapter.html
    Unless you mean you want just the cast piece and not the silicone inlet tube.
    Apr 21 2016
    Toronto, ON
    Quote Originally Posted by Silentmdrummer View Post
    Oh nice! I hadn’t seen this. That’s exactly what I’m looking for.
    Mar 31 2008
    eS-4
    CAL*SO
    DO NOT BUY A TB before porting the charger lol.
    Work on that first
    Jan 17 2015
    Quote Originally Posted by Fresh.S4 View Post
    Work on that first
    Not like it’ll hurt anything… just won’t give you much in the way of gains
    Apr 21 2016
    Toronto, ON
    Well you should own the adapter first, so that you can have it port matched when doing the supercharger.
    Jan 17 2015
    By the way guys, the VDO BMW N62 84mm Throttle Body part number is: 13547535308
    Can be found for $50 on eBay in good working order. Have fun
    Junior Member Two Rings
    Jul 19 2021
    southern california
    I have an Ultra charger I'm not using how much your you thinking it's worth? Remember Apr charges 1k for the tune! But any good tuner can make it work. Hilton dose great remote tunes!
    Jan 17 2015
    Quote Originally Posted by NewFoundLight View Post
    Probably not much anymore. This is the same basic design coupled with a larger throttle body for like half the price.
    Junior Member One Ring
    May 31 2021
    Manchester, NH
    Quote Originally Posted by Ashtonts View Post
    Hahaha I went right to it after I saw they sell the adapter. Someone wanted 55, guaranteed to work, best offer of 35 shipped, sold.
    Jan 17 2015
    Quote Originally Posted by Dross9779 View Post
    You did slightly better than me. $45 shipped for mine
    Mar 06 2019
    Indiana
    APR has CF and all the goodies, Buy umm I’ll take 1k for mine
    Established Member Two Rings BT719's Avatar
    Jun 29 2021
    2016 Dodge Durango Limited AWD
    North Central Florida
    Did you also buy lottery tickets yesterday? :)
    2013 Estoril Blue S4 DSG | Sports diff | 034 Stage 2+ Dual Pulley & TCU | SüperDüper TB | “wet charcoal” peelers | 034 RSB & end links | ECS chassis x-brace | 5% tint | RSNAV Apple CarPlay | proud stock exhaust
    Jul 01 2012
    Is this the same one that 034 is using in their kit or something?
    Sent from my LE2127 using Tapatalk
    Jan 17 2015
    Yes and you can buy them under 1/4 the cost of what 034’s selling them for (which to be fair is a reasonable price for a new one).
    Under $350 is cheaper than any of the hemi kits I’ve seen, and if that wasn’t good enough, the 034 adapter is a much smoother transition than the adapter with the cheap hemi kits, so it’ll introduce less turbulence to the flow = more air and less restriction. Cheaper and better.
    Jul 01 2012
    Yea that's not bad at all then only thing I'm wondering is how I can get it to work with my I.E tune since I have I.E.
    Jan 17 2015
    Supposedly it only works with 034’s tune.
    That said, throttle bodies aren’t that complicated so you can probably just repin the harness to work with IE’s tune. Obviously don’t quote me on this lol
    Apr 21 2016
    Toronto, ON
    It’s not about the pin out, but rather the throttle body size. IE’s tune won’t work because it’s not calibrated for an 84mm throttle body.
    Having throttle open at 25% on one size is not allowing the same amount of air in as another size. This is why you need a tune designed for the specific size.
    Feb 07 2018
    PDX ish
    ( ¬_¬)
    Sent from my SM-G973U1 using Audizine Forum mobile app
    2011 S line Prestige A4 Avant - 3.0t swapped
    EPL + 034 Stage 2+ DP ECU tunes| EPL TCU | CTS 187/57 | Roc-Euro Intake | PLM V2 Heat Exchanger | HR coilovers | Front BBK SPM Alcon 375mm | Rear BBK Voshmod 356mm| Milltek full resonated exhaust | test Pipes | 034 Endlinks | RS5 FBSW | 3g+| Deval CF Diffuser| BFI Knob | P3 Gauge| S4 Panda seats| Beaufort Aluminum Trim | RS5 Piano black MMI | S5 gauge trim
    Jan 17 2015
    Existing throttle body setups do have different pin outs though. For example, the IE tb needs to be repinned to run on an 034 tune. 034 also has a separate tune file for the Hemi tb kits vs the ultra charger because of the different pin outs.
    The extra 4mm diameter isn’t enough of a difference that it wouldn’t run…
    Apr 21 2016
    Toronto, ON
    This doesn’t make sense to me. The pin out would be corrected in the wire harness adapter. The ECU is going to send the signal to the existing wires, and the adapter then corrects the pin out for the throttle body.
    And 4mm translates to 10% more in area. Enough not to run, no, but definitely not optimal.
    Jan 17 2015
    10% more area is probably comparable to or even less than the difference the ECU has account for with varying temperature, DA, etc.
    Senior Member Three Rings Iwantyourcar's Avatar
    Jul 14 2018
    2010 Audi S4, 2019 Jeep Grand Cherokee, 1994 Oldsmobile Bravada
    Indiana
    Will this setup get me anything on a dual pulley EPL tune (Is it even compatible?)..SC is not ported either. Thanks
    '10 S4 / Koni / JHM / 034 Motorsports / ST Suspension / ECS / CTS Turbo / Maxton Design / Polo / EPL / Rotiform / Podi / Brembo / Stoptech
    Jan 17 2015
    Quote Originally Posted by Iwantyourcar View Post
    Talk to Chris at EPL. Again, this supposedly requires 034 tuning, but I would be surprised if you couldn't get it to work with existing tunes by repinning the harness. EPL does have tunes for larger TB's.
    You won't get a ton in the way of gains without porting the blower, but for the price of this thing you can't really go wrong either.
    Mar 31 2008
    eS-4
    CAL*SO
    port BEFORE throttle body folks. no sense in force the car to take big gulps of air if its got tiny lungs
    and yes, if epl and 034 have a hemi (80 or 84mm) tb file, then all you need to do is repin the harness, all you are just rerouting the signal to the correct pin that takes it. AND i believe the tb has to come from the older 1500 ram trucks, at least thats what a few folks on the fb have stated.
    ***74mm and 82mm porsche tb's do NOT require a harness and can run straight into the audi harness.
    Jan 17 2015
    Is anyone losing power from having too big of a TB though? I don’t think anyone who gets the TB before they port their blower is going to be hurting.
    Obviously dont get a big TB if you aren’t going to port your blower, but I don’t really see this mod doing any harm
    Feb 16 2019
    miami, fl
    Obviously don't get a big TB if you aren’t going to port your blower, but I don’t really see this mod doing any harm
    i don't agree with the not getting a big tb if not porting the blower, it makes gains by itself, and at the prices you can get them for it is a not crazy expensive option and is very quick and easy to diy and also to revert to 100% stock if you needed to for whatever reason.
    when testing was done between the iabed 75 and 82mm tb's the 75 made more power/torque overall for most systems, and the 82 gave some extra power on the very top end with the most aggressive setups (big pully ratio and ported sc)
    that being said not a ton of testing has been done regarding this. but in the end it was close enough to not be a real issue, with the conclusion that the vast majority of people benefited from the 75 compared to the 82 and the people that would benefit more from the 82 kinda already know who they are.
    Mar 31 2008
    eS-4
    CAL*SO
    i doubt anyones losing power, but why would you upgrade the tb? thats not the restriction.
    Feb 16 2019
    miami, fl
    i doubt anyones losing power, but why would you upgrade the tb? that's not the restriction.
    and you have data to back up the fact that the stock tb is not a restriction on a stock blower? just because there are other restrictions doesn't make the stock blower a non-restriction. i picked up between 1-2 10th's in the quarter going iabed 75mm, no ported blower yet. i have some iat issues to sort out (nearing 80c in south florida even with divorced hx) but dyno's have shown that upgraded tb's do make power, regardless of porting status of sc. hell the apr ultracharger came out before people were porting chargers and was known to make more power (and be a higher risk to factory cats as well)
    it's one of the restrictions. not the only restriction, but is one of them, and opening it up will create gains. will the gains be much more pronounced with a ported charger? yes, 100%. is there "no reason" to do a bigger tb without a ported charger like some are suggesting? no, and if someone wants to pay the dyno time I'll happily prove it. changing a tb is like 10-15 mins of work on this platform.
    Mar 31 2008
    eS-4
    CAL*SO
    yea bvhdr? testing was very nice to have as reference. thats what i went off of when making my tb decision.
    Mar 31 2008
    eS-4
    CAL*SO
    totally agree with everything you are saying.
    i am just saying from personal experience i believe the effort should be spent on the supercharger and NOT the throttle body as the order of operation, IF someone new had to choose.
    Dec 09 2020
    Dallas texas
    I have a IE 80mm tb for sale for 650$ obo plus shipping/pp
    Nov 13 2020
    US
    i wonder if the 034 TB will work with IE tune. Does IE have a HEMI TB file you can flash ?
    Jan 17 2015
    Quote Originally Posted by BIH2 View Post
    The 034 TB is a BMW throttle body, not a Hemi. Not sure if the hemi tunes will work right off the bat
