Results 1 to 7 of 7
    Jun 24 2020
    Somewhere
    Apr Ignition Coils
    I just replaced my stock coils with the APR coils and what a difference. With the stock coils I was getting a bit of hesitation. I dont believe there was anything wrong with them since i hadnt gotten any codes. My spark plugs had already been replaced as well. With the apr coils the take off from a stop is a lot better than previous and i havent noticed any type of hesitation. Dont know if anyone else has used them but that's my review. I'm all stock except for the coils and the turbo intake hose
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    I'm skeptical. Guys are running highly modified cars with high hp on stock coils on all Audi engine platforms. Maybe you had a bad stock coil that needed replacing, or just a loose connection.
    Glad you are running better. I hope you did not pay a lot more for APR branding. Wherever they got them, they outsourced them. APR does not make coil packs. My B8 Q5 3.0T is pushing 500 hp on stock coil packs. I realize your stock coil packs are different design than mine, but there is no reason to believe your stock packs can't support substantially higher than stock power.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Jun 24 2020
    Somewhere
    Quote Originally Posted by MSq5 View Post
    Yea it could be that my stock coils were bad but like I said I didn't have any type of codes. Also they only had 39000 miles on them. Not sure when they are supposed to be changed. The stock ignition coils actually cost more
    https://www.fcpeuro.com/products/aud...l-apr-ms100204
    Apr 22 2021
    san diego/ ca
    so you used the stock plugs that were already replaced when you changed out the coils? did you replace yourself and if so did you need a coil pack remover tool?
    2018 Audi A4 P+ Quattro Mythos Black
    AWE CAI | ECS turbo-back valved-exhaust | ECS strut brace | ECS FMIC+Charge pipes | 034 dynamic+ springs/RSB+end links/Trans Mount/FSB end links | GFB DV+| BlendMount+EscortMax 360 | RS4 grill+fog vents | Dynamic mirror signals | IE S2 ECU | Bilstein B8 Sport Shocks | CBF splitter/diffuser/mirror caps/trunk lip | WINTER--STOCK 18's--BFG G-FORCE COMP2 A/S+ | SUMMER--IWAutomotive FFP1 19X9.5--Michelin PS4S
    Jun 24 2020
    Somewhere
    Quote Originally Posted by jbap29 View Post
    Yep stock plugs which were replaced around 37000 miles. I just replaced the coils with the apr ones around 39000 miles. I did the work myself on the coils, just my hands no coil pack remover tool. A little dielectric grease inside the coils makes it easier to remove them next time they need to be pulled
    Feb 14 2017
    Gulfport, MS
    Zip tie loops made from long zip ties work well to pull out stubborn coil packs. And, they cost virtually nothing.
    Apr 12 2021
    California
    I also have stock coils, but after maintenance, I put the APR. I liked the first impressions, but it may be temporary, there were no special complaints about the stock, but they were a little more expensive.
