Results 1 to 8 of 8
    Jan 24 2012
    Tucson AZ
    Will they fit? 20 inch low profile tires to Q7
    We have a 2017 Q7 w 21" wheels. I have 20" HRE wheels on my S6 - 20x9, ET 35, 5x112 wearing Michelin PS4 265/35
    I'm considering swapping the wheels. I think the tires will not work, given that the standard ones are much wider 285/45. Anyone run a lowpro tire on the Q7?
    Stage 2 Banner Advertiser Four Rings Jimminez@Nemesis's Avatar
    May 16 2007
    2020 Q7, 2021 RS6 Avant
    Ottawa CA / DE USA
    Tires will definitely not fit. Nearly 9% smaller OD.
    Stock 20” Q7 wheels are 9” ET33 so technically the specs are similar enough but I’d check with HRE to see what they are load rated to.
    Jan 24 2012
    Tucson AZ
    Thank you for the quick reply! Guess I will sell
    These wheels and tires then. They looked fantastic on the Q7 though!
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    We all realize these vehicles don’t use the standard Audi 5x112 bolt pattern, right? Your wheels will absolutely not fit because the Q7 uses the Porsche 5x130 bolt pattern (as it does on the Cayenne and Touareg).
    So, no, these wheels will not fit.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Jan 24 2012
    Tucson AZ
    really? online, says they use 5x112, 66.5 CB. This is for a 2017 Q7 3.0T. You may be right though.
    Jul 04 2015
    Toronto Ontario
    Quote Originally Posted by hanyoung View Post
    https://www.audiworld.com/forums/whe...ttern-2916876/
    Jan 24 2012
    Tucson AZ
    Yes, but this is a 2017 (4M) model, not 2015.
    Jul 04 2015
    Toronto Ontario
    Interesting they made the switch.
