Originally Posted by
mrkubanftw
It has unfortunately been my experience. I'm tending to think perhaps dynamic maintains the last transmission mode it was in. If you were in sport-mode and switched to comfort it will automatically pull the car back into standard D, and i'm thinking when you go back to dynamic it automatically jumps back to S-mode. I don't know. Some testing could figure it out. I'd help but my car is on blocks right now :P
Sorry about being up on blocks.
If I select Dynamic which automatically selects "S" for me then pull back to select "D" if I then select Dynamic again it changes it back to "S" for me as I would expect.
Also if I go to "Auto or Comfort" and pull back to select "S" if I then go to any other mode other than Dynamic it switches back to "D". It doesn't maintain the "D/S" drive mode it was in when I was last in that Drive Select setting.
This is all how I would expect it to work too.
I do not believe that has changed on your C7.5 (I could be wrong), but Alabama has a C7 like me and it should for sure behave the same as mine.
Unless there is just some confusion on what is displayed on the dash?
When I switch to dynamic the dash show the "S" with an arrow down then the "D" indicating you are in "S" Sport and you can pull back to engage "D" Drive if you want.
Like this (ascii)
S
V
D
