Results 1 to 14 of 14
    Veteran Member Four Rings quattroism25's Avatar
    Jun 04 2007
    Exiled in Utah
    Question Denso Coil Packs
    Found nothing in the searches. Does anyone have any experience with these?
    https://www.fcpeuro.com/products/aud...05115g#fitment
    https://www.ecstuning.com/b-denso-pa...6e905115e~den/
    Daytona Grey S7
    MORO BLUE JHM modded V8 Sold
    Veteran Member Three Rings Burkeomatic's Avatar
    Feb 22 2021
    14 A8L 4.0T, 96 Corolla Wagon
    San Antonio
    No, but APR just rolled out some upgraded ones for $30 a piece though.
    2014 A8L 4.0T - DS1 Stage 4/JHM TCU, FE Axlebreakers, E85
    Established Member Two Rings ramboss6's Avatar
    Jan 26 2021
    uk
    There not available for 4.0
    Sent from my SM-N986B using Audizine Forum mobile app
    Veteran Member Four Rings ericw.'s Avatar
    Apr 23 2011
    C7 S7 4.0TT, Jeep JKU, MB GLB
    Sac Area, CA
    Denso is great quality. The only brand I use for certain components like o2 sensors.
    Sent from my SM-G986U1 using Tapatalk
    IG @lolzhax
    //AGILITYDRIVES.US
    C7 S7 4.0tt faster than kaploww and passed smog | LX7U | JHM STG3 ECU+TCU | JHM DP + CATBACK + Oil Screen Relocation + LW Crank Pulley + Heat Exchanger | SRM +4MM Turbos | S-FloV2 | EUROCODE SWAYS | CETE ASC | RFX7 | PS4S | RS7 FR+R | PD700R Splitter | Maxton Skirt+Spoiler Extensions | Indicator Delete | Hardwired
    b7 a4 2.0t | Stage 2+ | DTM Body [sold]
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    Supposedly APR is working on coils for the 4.0T platform.. Time will tell...
    The question I have is this.. APR, for example, posts a pretty graph showing their coils put out 10% more electricity than stock coils.. But what does this really translate to? Do you get any gains in engine power output at all? Or is this just more advertising to convince you they are really better and will improve your ride somehow?
    18 S6
    Feb 22 2021
    San Antonio
    Quote Originally Posted by Audisthesia View Post
    Well, his sig says he sold his V8 and now has an A6. But to answer your question, I don't know. There are rare instances where some more spark provides more power when the OE system isn't adequate. Are we in that boat? I doubt it. If some folks are having spark blow out problems, this may help. I haven't read about a whole lot of ignition related problems. When I do new coils, I'll buy these because they're only 5 bucks more a piece. I look at them as kind of an OE plus, if it helps me fine, if it doesn't, no big deal type of scenario. It isn't like they are trying to sell us $100 a pop coils though, they are still cheaper than the parts store. It is hard to tell what percentage of snake oil, and what percentage of actual upgrade these are until people start trying them, specifically higher power ones.
    I do agree however that Denso tends to make good electronics.
    Sep 16 2020
    West Michigan
    Quote Originally Posted by Burkeomatic View Post
    I would agree with your statements.
    If the 30+ year old ignition system on a Honda B series engine that uses a distributor and coil is good enough for 700+hp cars. I would posit that our factory ignition system is substantially better than that, so it is unlikely to have any dramatic effect.
    As stated, if buying through FCP Euro you maintain their warranty and they are only a marginal increase in cost it would seem more of a "why not?" at that point.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Aug 14 2019
    Tampa
    Yeah, if only 5 bucks over retail I'd drop a huge 40 bucks to use them on my 4.0T
    18 S6
    Veteran Member Three Rings prestige.phantom's Avatar
    Jul 16 2018
    Connecticut
    I am running those exact same coils on my car and they've been running smooth since I put them in! Look and install like OEM. For me, it was well worth it for the lifetime replacement. That being said, If FCP starts stocking the APR ones, I'll probably switch over (FCP stocks APR coils for GTIs and a few other cars so hopefully they start carrying them for the C7s).
    2013 Audi A6 3.0T Prestige
    | Phantom Black Pearl | Nougat Brown interior | LED Headlights | Cold Weather PKG | 20" Sport PKG Wheels & 3 Spoke Heated Wheel | Fine Grain Ash Natural Inlays | Michelin Pilot Sport AS3+ Y | OEM "Rings" Puddle Lights |
    | AWE Touring Exhaust | JHM Non-Res DPs | Eibach Pro Kit & Bilstein B4 Sport Shocks | Eurocode Trans Mount | JBX Carrier | S8 Front Brakes w/ EBC Red Pads | 034 ECU 93 STG 1, TCU, Rear Swaybar, and Endlinks |
    IG: @prestige.phantom @ctautoart
    Feb 22 2021
    San Antonio
    Quote Originally Posted by sepheroth86 View Post
    Very true, the car I was referencing getting power from the ignition was a early 80s bmw, lol. I didn't hit the limit of the factory ignition on my last build until I tripled the power output. I am not seeing many 900hp 3.0Ts running around, so I would say we're probably safe, but I could be wrong.
    Aug 14 2019
    Tampa
    Well, they are running 1000HP in EU on the 4.0, seems like stock coils do just fine.
    18 S6
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Is the issue that the coil produces more output energy for the same dwell time, or that the coil can reach the desired output energy with less dwell time?
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Aug 14 2019
    Tampa
    Don't know, thats an APR question.
    18 S6
    Jun 04 2007
    Exiled in Utah
    Thanks for the answers. I should've clarified, it's for the 3.0t A6. Pulled misfire codes on cylinder 5. FCP is down the street from me so I'm going with the denso. First time changing coilpacks so I didn't know if its one "you get what you pay for" parts.
    Daytona Grey S7
