Originally Posted by
Alabama
From the 2012 4.0 engine self study program: "Cast pistons with a cast-in ring carrier for the compression ring are used in all engine versions. The principal difference in pistons for the engine variants is the shape of the piston crown." The difference in the accompanying pictures appears to be a larger diameter concave area in the center of the piston crown for the high horsepower variant. Mahle makes aftermarket forged pistons for smaller VW/Audi engines, but not for the 4.0t. In an old AZ post, DeerHunter wrote "Cast pistons are not terrible, in of of themselves. If knock is kept under control, there are essentially no downsides (and many upsides, since cast pistons wear better, are quieter,etc.). The fact that Audi uses cast pistons for all versions of the engine (including the S8 and RS6/7) speaks volumes for how tough they are. This wouldn't be one of my concerns, unless you're planning of building a 1,000 hp monster, in which case you're better off starting with another car."
For 99% of street builds, a cast piston is absolutely fine. Now will a forged one give you more margin of error for preignition or other irradic events that can kill a piston? Absolutely. When I built the engine in my miata, I did a rods only build. Everyone knew that you would ventilate the block at around 300whp from the rods breaking, but folks just went ahead and replaced pistons as a precaution, but swore up and down you would need them. My car made 350+whp for years before I finally got rid of it. Everyone swore my shitty little $800 short block with $150 valve springs and ported by me heads was going to grenade any minute, but it wasn't to be. That engine is currently throwing down 400whp in another car. That is like a 4.0t making over 800whp with port injection, wasted spark, and crappy cast pistons designed in the 80's.
However, if you want to rev higher, and have lighter pistons, and more margin for error, then by all means get them. I just couldn't justify increasing the cost of a build 160% for something not proven to be needed, and it turned out I actually didn't. If your tune is on point, the pistons will be fin, and I am pretty sure that logic applies from carbs to direct injection.
