Results 1 to 10 of 10
    Junior Member Two Rings
    Jun 12 2021
    New York
    AUDI S5 B9 MANUAL in S MODE
    So I've seen some YT videos of people going to manual from S and the gears would show S1, S2, S3, S4...etc...
    When I shift from S to manual, goes back to M1, M2, M3..... and the valves close up.
    Is OBD 11 the only way to enable manual in S mode? It'd be perfect. Manual S mode
    Got back my car from the shop. XPEL STEALTH + CERAMIC COATING + XPEL CERAMIC TINTS + BLACKED OUT ROOF.
    Cant get decent pictures cause weather is terrible in NY right now
    Junior Member Two Rings jas9's Avatar
    Dec 28 2020
    Orange County, CA
    There is no manual s mode. The coding in obd11 just shows the gear you’re in while in S transmission. You can also use other tools like VCDS to enable this, but obd11 is the easiest.
    Jun 12 2021
    New York
    Quote Originally Posted by jas9 View Post
    When Im in S automatic mode, the exhaust is louder than going to manual. Is it just me or does the valves close when you go from S to manual?
    Dec 28 2020
    Orange County, CA
    Quote Originally Posted by jkim20 View Post
    Yeah in S the valves are opened and it idles at a higher rpm. I also experienced the same where in D or M at idle the valves are closed and idle is lower.
    Jun 12 2021
    New York
    Theres no way to Stay in S and go manual mode? When I go shift over to manual from S mode.. sounds like the valves close
    Dec 28 2020
    Orange County, CA
    I don’t believe so. From my experience, S has its own programming to open the valve at idle, while the other modes seem to open while driving when needed. You could get a valve controller like CETE to have manual control over the valves.
    Jun 12 2021
    New York
    that sucks
    Senior Member Three Rings dal59's Avatar
    Mar 31 2021
    2021 RS5 - 2022 BMW X3 - 2002 Harley Wide Glide
    atlanta
    Just wish to clarify. Are you switching into Manual mode by moving the shifter over to Manual, or by using the paddle shifter to switch in to manual mode? I am not sure it will make a difference with the exhaust, but I seem to think I saw an MS1. If so, this would indicate it was both in manual and sport. Maybe it is different with the RS5 or maybe I am just not remembering correctly??
    Mar 19 2019
    In my experience, if you are in S and shift to M, it is S in manual mode. However, it doesn’t show M1S. If you let it idle, you can see that rpms are still higher like when you are in S automatic.
    2019 Audi S5 Sportback Prestige - Mythos Black, Dynamic Steering, S Sport Package.
    Veteran Member Three Rings Unleaded20T's Avatar
    Mar 27 2008
    Ducati Streetfighter V4S
    Allen, TX
    There is a mod you can do with Vagcom or OBD11 to have it display the gear next to the mode, either D1, D2, D3 or S1, S2, S3... or M1,M2,M3..
    Enable Automatic Gear selection shown in DIS
    [02 – Auto Trans] [Adaptation – 10]
    Select “Single Gear Display” from top channel drop down menu
    Select “D on/S on” from New value drop down menu
    [Current] 22' S6 | Daytona Gray | BO | Prestige
    [Sold] 21' S5 SB | Glacier White | BO | Prestige
    [Sold] 19' SQ5 | Ibis White | Prestige
    [Sold] 2016 A6 | Moonlight Blue | 3.0T P+
    [Sold] 2011 A6 | Black | Prestige
    "If everything seems to be under control, you are not going fast enough." - M.A.
