Yeah, I was still on 3Mbps DSL when I did my day, made sure everything else was off that day. Nowadays, 300Mbps fiber, no big deal. The file set I downloaded way back when was almost 200MB. But you want that documentation if you're doing your own work on the car.
The rear is nothing, one nut, two smaller bolts, one large bolt, each side.
The front has a number of things that were changed over time. With a build date of Nov 14 '10, the specifics get locked down though.
Take the nut on the tie rod end ball joint, number 10 on
https://www.ilcats.ru/audi/?function...10&language=en
The workshop manual designates this nut as a replace if removed. So which number 10 do you replace it with? The chart on the page shows the hex collar nut used from Jan '08 to Dec '08, then the 12-pt shouldered nut from Dec '08 on. So you're going to need WHT 004 593.
https://www.genuineaudiparts.com/oem...-nut-wht004593 $5 a pop, but classified as replace if removed because it's self-locking. Would some threadlocker blue be sufficient to reuse it? Who knows. It's $10, how often are you doing this?
Likewise, on
https://www.ilcats.ru/audi/?function...01&language=en
you see the pinch bolt was changed on Jun 6 '11. But throw that part number into ECS or parts.audiusa.com, you see it's been replaced by WHT 007 963.
You see the reduced center shank in the pics -
https://www.ecstuning.com/b-genuine-...ach/wht007963/
It's not the "correct" bolt per say for your pre Jun 6 '11 build, but I imagine it's what anyone is installing these days.
You can see the older style one -
https://www.ecstuning.com/b-genuine-...ach/n10491802/
If we look at nut 6A for the lower straight control arm ball joint, again, two versions with dates. But also notice in the tech information, one is M12 and one is M14. That's because the ball joint was upgraded from M12 to M14 on that date. So clearly you have to use the correct one for your build date as the other one won't even fit.
etc, etc, etc.
Stretch bolts only stretch correctly once. And it doesn't have to have a +° to be a stretch (aka TTY) bolt.
