Results 1 to 19 of 19
    Junior Member Two Rings
    Nov 27 2020
    2000 TT quattro 5 speed, 2004 A4 3.0 quattro 6 speed, 2001 S4 Avant 6 speed
    Woods Hole, MA
    "best" rotor choice help?
    I would like to replace my front rotors and can't seem to determine what is a good choice. '07 A4 Avant with v6, not particularly spirited driving. Buying the Audi rotors at 3X$ other brands seems hard to justify. Brembo, Myle etc all are reputable and created equal? Part of the reason I ask is that a set of (FCP I think) rotors failed to ever really develop good smooth operation and now are pretty awful. It's possible I did not properly remove the coating at installation. Anyway, kind gun shy so ask here. Did a search and couldn't find anything like a FAQ
    Established Member Two Rings ultima's Avatar
    May 31 2019
    Ft Lauderdale/Toronto
    Bosch is a safe bet for rotors, not too much and they've worked perfect in my experience.
    May 20 2010
    I've had good success with Centric high carbon discs
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Jun 17 2013
    jersey city nj
    I never had issues with authentic Brembos. I these 2 years ago. Still like a champ
    Jun 17 2013
    jersey city nj
    FCP also has a lifetime warranty on parts. Just call them & get a new set
    Mar 24 2013
    Oakdale, CT
    Zimmerman is a good cost effective brand for stock replacement rotors.
    -Adam
    Aug 18 2020
    Sonoma, CA
    I 2nd Zimmerman.
    Established Member Two Rings BillyK's Avatar
    Jul 22 2016
    Washington, DC
    I just replaced all 4 corners with Zimmerman rotors and Akebono pads. They work great and very little dust.
    Account Terminated Four Rings
    Oct 15 2013
    I tried Meyle for my other car and they were fantastic. Where do you find Meyle rotors? FCP Euro stopped carrying them for my other car.
    Veteran Member Four Rings Zolli's Avatar
    Sep 29 2016
    2011 Q7 TDI
    Scottsdale, AZ
    Has anybody ever tried Coleman Racing? I’ve been sniffing around their website for some replacement rings.
    OP, be sure to do the full bed-in procedure when you replace your rotors. You may already know this, but it makes a very disconcerting grinding noise.
    Jun 27 2011
    I 2nd Centric High Carbon.
    - - - Updated - - -
    Quote Originally Posted by vce1232000 View Post
    Mr. Fancypants here and his 2-piece rotors...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Jun 17 2013
    jersey city nj
    - - - Updated - - -
    They dont make a 1piece rs4 rotor 🤣🤣🤣🤣
    Feb 20 2016
    Greenville SC
    I agree with this , have them on 3 audis currently
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Ive run Zimmerman in the past, and its a quality option.
    Many people love basic Centric rotors, and they are also a budget friendly yet quality option. I have used StopTech on the Audi's over the last few years. StopTech is Centric's performance line and if you shop around for really great deals.
    I have a ST40 BBK setup on the B7, and rotors/sport pads/SS lines on the S3.
    2019 SQ5 Prestige
    Mar 04 2019
    Staten Island, NY
    I use the Raybestos brand coated both front an back with the element3 pads. Also for more stopping power you can do a fluid flush and refill
    You a bounty hunter...Man's got to do something for a living these days......Dying aint much of a livin boy....
    Veteran Member Three Rings Cyrik's Avatar
    Oct 03 2017
    2007 Audi A4 2.0T Quattro
    Brake Performance has been a good brand to me, their Drilled/Slotted rotors kit is affordable and decent. My only complaint is their ceremic pad options (they suck) when you buy a kit from them. I also had my front rotors warp but that was probably because my front struts were blown, it was bound to cause an issue.
    '07 A4 2.0TQ Tip: JHM Stage 2 Tune, 18" Sparco wheels, CTS Turbo 3" HFC w/ 2.5 - 3" custom exhaust, ECS Luft-Technik IC w/ custom AEM intake, GFB DV+, 034 control arms/tie-rods/strut mounts/engine mounts, ECS snub mount, Bilstein B4 shocks, BrakePerformance D/S rotors and have replaced LITERALLY EVERYTHING ELSE.
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    Quote Originally Posted by Zolli View Post
    For which hats?
    I was going to send in my ECS hats to get new rings built. I would assume they’re similar to most oval track rotors anyway.
    I also need to have them make a custom set of rear rings for my 330mm Brembo caliper upgrade.
    If you’ve got the same 18z setup, we might be able to get a group buy going.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Sep 29 2016
    2011 Q7 TDI
    Scottsdale, AZ
    Quote Originally Posted by james12lucy View Post
    For which hats?
    I’ve got the two-piece Brembo 4-piston GT version front and rear. 355x32 fronts, 345x28 rears. I need new rings for the fronts, exploring some options.
    My Q7 might have the 18z, I’ll have to check. I’m down for a group buy.
    Jul 04 2015
    Toronto Ontario
    Nice setup you have there!
