Results 1 to 11 of 11
Thread: NEED HELP
    Junior Member One Ring
    Mar 16 2021
    Dominican Republic
    Exclamation NEED HELP
    My A6 C7 2012 I have this error
    igniter 1 for pedestrian protection
    Error: B103811
    Short Circuit to ground
    But my A6 C7 don't have a pedestrian protection bumper that raises or pistons near the bonnet hinge/
    I need to solve this, please
    Thanks in advance.
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Online readings point to a faulty airbag control module. Especially since you don't have the pedestrian protection feature.
    i.e the fault code is able to be generated by the general airbag control module even though the pistons/bumper/whatever don't exist.
    Did you recently have any other work done?
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II 12.868@107.8 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I 14.746@95.29 3944lbs
    Mar 16 2021
    Dominican Republic
    I get a brand new new steering rack installed
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    I believe the pedestrian protection feature is referencing to the passenger seat sensor to engage/dis-engage the airbag for the passenger.
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Mar 16 2021
    Dominican Republic
    Interesting i will check that asap. i will check connectors
    Mar 16 2021
    Dominican Republic
    ll connectors are ok all good! problem Still
    Mar 16 2021
    Dominican Republic
    some body can help with this please ? !
    Mar 16 2021
    Dominican Republic
    still need help !
    Mar 16 2021
    Dominican Republic
    Still problem nobody can solve this even Audi house
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by TexasDfwS4 View Post
    Maybe but maybe not. What I'm reading is that Audi was concerned that a car might accelerate in an unintended fashion and try to run over a pedestrian. Therefore, a passive system was developed that would set off a pyrotechnic charge that would in turn extend pistons on either side of the hood and move it backward and upward a little bit, so as to move the hood away from the pedestrian. I saw a self study manual for the 2013 A3 that mentions this system, but I can't find a mention of it in the 2014 S6 manuals I downloaded from erWin (certainly could have missed it). Maybe the 2012 A6 does not have this feature, but when OP had work done on the car, some new component was added that is looking for this non-existent part. As gk1 wrote in post #2, it makes sense that such a system would be tied into the general occupant safety system. Hopefully smarter AZ members know about this and can help OP.
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Established Member Two Rings HolyHell's Avatar
    Mar 24 2021
    1986 GTi, 2013 S6, 2010 GTI, 1993 Toyota Truck
    San Diego
    Have you tried clearing the fault and seeing if it returns? Maybe faults weren't cleared after adaptation of the steering rack.
